Old 05-26-2015, 04:23 PM   #21
Pete
Default Re: Stroker 21 stud
Originally Posted by Ronnieroadster View Post
Pete I would think a lot of clearance in the block would be needed for the 4.750 stroke ending up opening into the water passage was the block filled solid?
Ron
I haven't tried it with modern H beam rods. With 21A rods some grinding on the block was needed. No where near getting into water..The big problem was the extremely short skirt required on the pistons. It hurt ring life with .012/.014 clearance.
Old 05-26-2015, 04:30 PM   #22
KiWinUS
KiWinUS's Avatar
Originally Posted by scooder View Post
Thanks for that John, they do look sharp! If they got those patterns maybe they got the four carb manifold pattern too. That would be brilliant. I want me a Sharp four two.
Martin.
They are very "SHARP"
I dont believe Al Sharp made any 21 stud heads .
Man I love them !!!!
It will be tough for me to decide which of my Sharp intakes to run with those heads , or my "Burns" intake would also look way cool !!!
KiWinUS is online now   Reply With Quote
Old 05-26-2015, 09:18 PM   #23
38 coupe
38 coupe's Avatar
If I were having a crank welded I would start with a used crank. You are going to have to straighten and grind the journals afterwards anyway. Why do that to a new crank? What other crank are you going to find that will fit all those NOS standard bearings out there?
Allard, Tornado, and those weird waterless Federal Mogul heads are the only center water 21 stud aftermarket heads made back in the day that I know about.
edit: I meant Cyclone, not Tornado, wrong bad weather reference.
Old 05-26-2015, 09:23 PM   #24
JM 35 Sedan
JM 35 Sedan's Avatar
Tony, they do look very nice!! Let me know if you hear anything on the actual cost for a pair of these for pump in heads.
John
Old 05-26-2015, 09:39 PM   #25
Tinker
Tinker's Avatar
The Eddie Meyers go for 1100. Being that there is no other heads it might be comparable. Probably a deal if you want 21 finned aluminum heads.
Downloaded h&hs catalog off thier website for 2015. Man they are really keeping flatheads going. Much respect.
Old 05-26-2015, 11:13 PM   #26
tubman
tubman's Avatar
In the late '50's, I had a set of Cyclone 21 stud center outlet finned heads. Try as I might, I couldn't make them work on my '36.
Old 05-27-2015, 04:02 AM   #27
KiWinUS
KiWinUS's Avatar
i bet they looked alot like these heads ...wink wink ...
why would they not work ?
Old 05-27-2015, 08:01 AM   #28
JM 35 Sedan
If stock '36 engine and center outlet heads, there would be no place for water pumps
John
Old 05-27-2015, 08:03 AM   #29
KiWinUS
KiWinUS's Avatar
good point John , I was thinking 37 block .
Mike text me pics yesterday also , I will let you know when I get any price info.
Old 05-27-2015, 08:26 AM   #30
Ol' Ron
Ol' Ron's Avatar
I wonder if the spark plug is still in the original location? Be nice if the people that take the trouble to make these heads, would take the time to up grade the combustion chamber.
Old 05-30-2015, 04:20 PM   #31
flatheadkid1
flatheadkid1's Avatar
SCAT makes stroker cranks for the small journal 21's. Check out their part number 9-221-4000-2000.
flatheadkid1 is offline   Reply With Quote
Old 05-30-2015, 08:57 PM   #32
Brian
Brian's Avatar
Thanks for that most interesting information...hmmm...now you've got me thinking.
Has anyone on here got first hand experience with the above Scat crank?
Old 05-30-2015, 10:13 PM   #33
Flathead
Flathead's Avatar
With that 4.750 crank did you run the real early style rods for cam clearance etc.? Must have been tight in there. I do like big motors though.
Flathead is offline   Reply With Quote
Old 05-30-2015, 10:22 PM   #34
JM 35 Sedan
That is interesting. I wonder what mains diameter you could get on these stroker crankshafts? It really didn't say in their on line catalog.
John
Old 05-30-2015, 10:40 PM   #35
Pete
21A rods.
Old 05-31-2015, 01:30 AM   #36
flatheadkid1
I called them a few months ago and they verified that part number had 2.399" main journals with a 4" arm. I did not ask if it had an oil slinger. At that time they had no stock and the price was high (don't remember exactly how much) but it may be possible to get one at a lesser price if it wasn't purchased direct from SCAT.
If a late merc crank was ground to 2.399" on the mains how would one address the oil slinger/ rear main seal. There is not enough diameter there to create the slinger. Boring the mains out to use the 2.499" bearings and using a 59A rear main cap with a seal seems possible but expensive.
Old 05-31-2015, 04:52 AM   #37
colin1928
colin1928's Avatar
Slingers can be added simply by soldering
colin1928 is offline   Reply With Quote
Old 05-31-2015, 08:11 AM   #38
Ol' Ron
Ol' Ron's Avatar
In the 37/38 block, Reds headers mad an adapter to convert to the rope seal, Using several Ford parts, Pretty simple
