Old 05-07-2010, 08:46 AM   #1
PeteVS
PeteVS's Avatar
Default Repairing splines?
I've got a nice 3.54 ring and pinion set. Only trouble is the pinion spline has been seriously hammered. Should it be possible to build up weld on the worn faces of the spline and remachine it? Thanks!
Old 05-07-2010, 08:51 AM   #2
Da Tinman
Da Tinman's Avatar
Default Re: Repairing splines?
I dont think so.
No expert on the subject by anymeans but welding and such would change the hardness of the pinion and make it brittle.
Unless its a gear set made of un-obtanium I'd just replace it.
Da Tinman is offline   Reply With Quote
Old 05-07-2010, 08:54 AM   #3
uncle max
uncle max's Avatar
Weld it with UTP 65 stick electrode. High nickel-chrome, 130,000 tensile, 40% elongation, free machining and work hardens just right...
uncle max is offline   Reply With Quote
Old 05-07-2010, 08:57 AM   #4
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
Absolutely, any competent machine shop can do this.
Ross in East Texas is offline   Reply With Quote
Old 05-07-2010, 09:32 AM   #5
Bruce Lancaster
3.54's are not quite unobtanium, but good originals are hard to find and can be pricey... definitely worth fixing.
Old 05-08-2010, 07:41 PM   #6
Pete
I have tig welded them up and remachined.
This was for a street application and it is still running 15 years later.
I don't think I would consider doing it for a high horsepower car.
Old 05-08-2010, 08:02 PM   #7
PeteVS
PeteVS's Avatar
Did you use any kind of special filler?
Old 05-08-2010, 09:26 PM   #8
Pete
I used SAE4130 wire.
Old 05-09-2010, 02:08 AM   #9
Da Tinman
Da Tinman's Avatar
Coming from a racing background this just sounds like a bad idea, but I will bow to the experts.
