Repairing splines? I've got a nice 3.54 ring and pinion set. Only trouble is the pinion spline has been seriously hammered. Should it be possible to build up weld on the worn faces of the spline and remachine it? Thanks!
Re: Repairing splines? I dont think so.
No expert on the subject by anymeans but welding and such would change the hardness of the pinion and make it brittle. Unless its a gear set made of un-obtanium I'd just replace it. |
Re: Repairing splines? Weld it with UTP 65 stick electrode. High nickel-chrome, 130,000 tensile, 40% elongation, free machining and work hardens just right...
Re: Repairing splines? Absolutely, any competent machine shop can do this.
Re: Repairing splines? 3.54's are not quite unobtanium, but good originals are hard to find and can be pricey... definitely worth fixing.
Re: Repairing splines? Quote:
This was for a street application and it is still running 15 years later. I don't think I would consider doing it for a high horsepower car. |
Re: Repairing splines? Did you use any kind of special filler?
Re: Repairing splines? Coming from a racing background this just sounds like a bad idea, but I will bow to the experts.
| All times are GMT -5. The time now is 11:20 AM. |
