Old 01-02-2015, 09:47 PM   #1
jboggess
jboggess's Avatar
Default Happy running T again.
Just getting around to posting this but,, the last 2 warm seasons my T hasn't been running good at all, to even get it to go down the road decent the spark had to be advanced all the way down,, so i cleaned the timer out, cleaned the carb out,checked the plugs, no matter what i did it just didn't do anything for it. So i decided it was time for a brand new timer and roller. After pulling the roller this is what i found. Gotta say the car has never ran better. Sooo check your rollers.
jboggess is offline   Reply With Quote
Old 01-02-2015, 10:21 PM   #2
Steve Jelf
Steve Jelf's Avatar
Default Re: Happy running T again.
Or use a New Day timer.
Steve Jelf is offline   Reply With Quote
Old 01-02-2015, 11:15 PM   #3
J Franklin
J Franklin's Avatar
It is hard to believe you had not found that when you cleaned it up.
Old 01-03-2015, 08:09 AM   #4
DanJohnston
Congratulations, on figuring the problem out on your own! I can't tell you the number of times I would have kicked my own A-- for not being able to see the Forest for the Trees!
They are a lot more fun when they are running well! Dan Ph. #: 701-200-2319
DanJohnston is offline   Reply With Quote
Old 01-03-2015, 09:20 AM   #5
Royce P
Royce P's Avatar
If you pack the timer with Vaseline or red bearing grease that won't happen again.
Royce P is offline   Reply With Quote
Old 01-03-2015, 10:00 AM   #6
CharlieB
CharlieB's Avatar
I believe Ford recommend Vaseline but how does it hold up to the heat? Pretty sure a decent high temp grease like Royce is using wil be OK.
CharlieB is offline   Reply With Quote
Old 01-03-2015, 03:56 PM   #7
jboggess
jboggess's Avatar
Interesting,, so why is grease better then oil, wouldn't you want to use something that flows? Thanks a bunch.
