Is there an easy way of removing the lock ring that holds the grease seal and bearing in the rear hub? Thanks all, Al
A couple of thin blade screwdrivers and good eye protection
Take small 'bites' with the screwdrivers and slowly work it out of the groove Good Luck |
Exactly how I remove the ring. The tricky part is removing the seal. Don't bother trying to save it, just have a good claw hammer or pry bar and go at it. Many new seals are too tight and will distort if you drive them in. You may have to sand the O.D. to make them fit. Be sure to blow any sanding dust away, then grease the bearing and seal lip. Don't drive the seal in any more than just enough to get the snap ring back in place.
