Old 06-01-2026, 04:00 PM   #1
Sunnybob
Sunnybob's Avatar
Default 1953 Mercury Power steering Cylinder
Hi Folks,
I'm adding power steering to my 1953 Monterey and I have found almost all original parts. The power cylinder has small leak so I was thinking to buy another one. Rockauto has two types.
Lares 30 has external tube, like mine, but is only Remanufactured and the core is a problem for me as I live in Italy. The other one, lares 10031 is new and cheaper.
Has anyone tried swapping them and know if they are more or less interchangeable?
Thank you.
Sunnybob is offline   Reply With Quote
Old 06-01-2026, 06:05 PM   #2
pistonbroke
Default Re: 1953 Mercury Power steering Cylinder
they swap out but you may find the hose ports are a different size and so new custom made hoses would be needed or an adapto. Over the years I have swaped many PS rams. The anchor to the steering gear and length are the important points to consider.
Old 06-02-2026, 06:52 AM   #3
Sunnybob
Sunnybob's Avatar
Thank you so much, I really appreciate your post
