The Ford Barn
-   -   1953 Mercury Power steering Cylinder (https://www.fordbarn.com/forum/showthread.php?t=357940)
Sunnybob 06-01-2026 04:00 PM
Hi Folks,
I'm adding power steering to my 1953 Monterey and I have found almost all original parts. The power cylinder has small leak so I was thinking to buy another one. Rockauto has two types.
Lares 30 has external tube, like mine, but is only Remanufactured and the core is a problem for me as I live in Italy. The other one, lares 10031 is new and cheaper.
Has anyone tried swapping them and know if they are more or less interchangeable?
Thank you.
pistonbroke 06-01-2026 06:05 PM
Re: 1953 Mercury Power steering Cylinder
they swap out but you may find the hose ports are a different size and so new custom made hoses would be needed or an adapto. Over the years I have swaped many PS rams. The anchor to the steering gear and length are the important points to consider.
Sunnybob 06-02-2026 06:52 AM
Thank you so much, I really appreciate your post :)
