Old 05-09-2026, 10:53 AM   #1
[email protected]
Default 37 Flathead oil leaks
Excessive oil leaks that appear to be front of engine ( not from cotter key hole) any easy fix, I plan to increase viscosity ( 20/50) and I put on a new breather, should I put on a PCV ?open to suggestions,37 cabriolet is 98 % original open to suggestions
ranrou1@cox.net is offline   Reply With Quote
Old 05-09-2026, 10:45 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 37 Flathead oil leaks
Cover your distributor with saran wrap and give your engine a bath, then get back to us with exact location and amount of leakage. 20/50 sounds good in any case.
Alan
Old 05-10-2026, 01:12 PM   #3
mcgarrett
Maybe start by tightening the bolts on the oil pan, timing gear cover, distributor, etc. and see if that makes any difference.
Old 05-10-2026, 01:07 PM   #4
Ggmac
I would not recommend pcv . The 37 uses no rear seal so youd be sucking dust from the clutch area using a pvc
Old 05-10-2026, 01:08 PM   #5
Ggmac
You need to do as suggested. Clean the motor and be more specific, picture will help
Old 05-10-2026, 05:44 PM   #6
mfirth
What mcgarrett said x 2, but do not over tighten the pan bolts.
mfirth is offline   Reply With Quote
Old 05-11-2026, 01:55 PM   #7
1956 ford
A 20/50 is no more then a 20 thought all operating temp go to a 30
1956 ford is offline   Reply With Quote
