Yesterday I went on a club tour and the car never ran better. But, I came home with another dress shirt that has grease on the left shoulder from the female dovetail on the door jam. I don't realize it when it happens but to get my feet through the opening, I must be leaning back into the greasy slot in the dovetail. Has anyone else experienced this? When I am stepping out, going on a tour or a club meeting, I usually am wearing one of my better shirts.
Can anyone recommend a clear, heavy grease or other lubricant? Currently, I am using a heavy black wheel bearing grease. Thanks for your help. Ed |
I see your problem although I haven't had it yet. I wonder if a clear piece of tape on the face of dovetail might work. Better yet, a piece of clear plastic sheet covering the entire face and secured with the dovetail's mounting screws.
Bob Bidonde |
Someone gave me a duster, which is basically an overcoat to be worn while driving your pre WWW1 brass car on the dusty roads of the time. That may be a solution. You can put it on to drive the car and then take it off when you get to your destination. An old jacket would serve the same purpose. A light weight jacket for summer or Florida.
If it’s on your shirt …sooner or later on seat?
Remove the grease...................
Paul in CT Mine never had it. |
TOB |
Take the shirt off before you get in the car.
#8 | |
I noticed a hole on either side of the four dovetails on my Town Sedan and inside the dovetail has a piece of felt (the dovetails are hollow). Occasionally I wipe them clean and put a few drops of light oil in the holes. I don't know if this was what the holes and felt were originally meant for but it appears to be and seems to work. Last edited by Y-Blockhead; 02-27-2022 at 10:27 AM. |
I wonder if those holes would be for rubber bumpers?
wear a slicker..............
as what yblockhead wrote, that is what the holes are for, oil
Victoria is merely marking her territory!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
#13 |
wear a black shirt.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
#14 |
I use bee's wax on my victoria
#15 |
Silicon spray is better for door locks here, dust doesn't stick and wear them out. Spray often. It dries clear.
Wash out the grease first tho. |
#16 |
Clear tape What?
#17 |
Originally the dovetails had felt inserts. The holes are to allow oiling not greasing I would suppose
#18 |
I have had good luck using Shout on grease stains!
#19 |
#20 |
I would say if everything else that could go wrong isn't, this is the least of your worries.
