Need a shortened pitman arm for better steering. Need a source to buy. Thanks
All the big parts houses have em now, Try Mikes or Snyders, I am pretty sure they have new ones now.
IN the Winter 2010 Issue of the Model A Times we reported on Snyder's new short pitman arm. Not a modified original but brand new.
Contact Snyders, you won't be disappointed ! Wayne
I have 2 problems with this one:
Shortened Pitman Arms only come LHD we have to heat them and twist them to face the "right" way. A dissapointment! Contact Snyders! Not likely. They seem to not want to deal with anybody outside US now. Their new website has a "Contact Us" form where a phone number is required. Our telephone numbers have more digits than those in the US. The site won't recognise them and won't allow the message to be sent. Seems dealing with Snyders has just been taken off the table. Can't understand their business smarts cutting so many customers adrift.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#7 | |
Mitch, No I haven't rung them. It's easier to stay with my other supplier. I doubt a call would do anything anyway. Quite some time ago, I suggested they change some of the advice they were giving. For example, they used to say that con rods should be installed with the dippers facing the passenger's side. If we weren't on the ball, that would end in disaster and they would be up for making good the damage. I suggested they tell people to install them facing the cam shaft but years later, nothing had been done. There are other examples but I'll leave it at that for now.
Can you explain why you would want to use a shorter arm? I've used longer arms in the past to make the steering quicker, I'm not sure with vintage boxes why you would want to make it slower?
Ok. Thank you.
You may need an adjustable drag link to center the steering.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
#13 |
Hello Thomas,
You need to know the shortened pitman arm is not a cure for poorly maintained steering components, as mentioned you will most likely need a adjustable drag link.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
#14 |
I rebuilt my steering box with the needle bearing sector housing,installed a shortened pitman arm, and installed nylon inserts in the tie rods and pitman rod. no need for an adjustable pitman rod. You wouldn't know it was the same car. Steers wonderfull and light. I love it.
#15 |
I've tried to upload a photo but it all just seizes up once I've uploaded and hit the close this window button.
#16 | |
http://www.fordbarn.com/forum/showth...ading+pictures PS. I use IrfanView http://www.irfanview.com/ to resize photos. |
#17 |
I bought mine from Brattons. Good quality but it increases the turning radius. Difficult in tight spaces.
#18 |
If you search past threads you would not have this problem.
#19 |
Didn't hurt the turning radius on my roadster. I still turns lock to lock and is better than the power steering on my Lincoln if the car is in motion. First Model A I ever had that returns after a turn, but I had 7 tooth steering and changed that to the 56 Ford at the same time as the shorter arm. Very easy to drive now. Next will be a synchro so the bride can drive it. You will love it I'm sure.
#20 |
So, what is the length of the stock pitman arm? And, how short is the shorter version?
Asking because I'm new to fixing Model As. Owned and drove a few of them years ago but didn't do much fixing, just drove them and replaced parts from an auto wreckers when parts were needed. Right now I'm working on a "refurbished" '31 CCPU that I need to get ready for the safety inspection before I can insure and license it.
