10-13-2023, 01:18 PM | #1 |
Stipe Machine/Specialty Motor Cams
Is Stipe Machine/Specialty Motor Cams still in business? Their phone number and website are not working.
AL in NY |
10-14-2023, 07:19 AM | #2 |
Re: Stipe Machine/Specialty Motor Cams
Thread on the other site said they are in the process of moving to Kentucky.
04-17-2024, 03:10 AM | #3 |
04-17-2024, 11:46 AM | #4 |
04-17-2024, 07:33 PM | #5 | |
04-18-2024, 11:08 AM | #6 |
04-19-2024, 02:12 AM | #7 |
I had been corresponding with Stipes since Jan. of 2023 about a camshaft. I was
on the waiting list and had been getting updates from them. Then all of a sudden they went radio silent in June of 2023. No answer to emails. The latest email I have is: [email protected] There has been problems getting cam cores for many different makes of engine after COVID. I have a friend that was getting so tired of it that he has gone into the cam core business. We just received two from him, one a small block Ford and the other a Big Block Chevy. We are doing a cad cam drawing of the Model A cam to see what its going to take to make cam cores. They would be a steel billet. |
04-19-2024, 06:16 AM | #8 |
I got my Stipe shocks 2 years ago. Visited the shop in Plymouth, WI. I know there are lots of Model A'ers in WI and perhaps someone could stop at the shop for a look. Close by would be Manitowoc, Sheboygan, Fond du Lac, Two Rivers, Kohler, Port Washington, Kiel etc. Be a nice A ride as well. Bill
04-19-2024, 07:15 AM | #9 |
Dodge, If you make cam cores, make them with 5 bearings. That way they will work in the Burtz block. Not that the 3 bearing cams will not work but that the 5 bearing cams take advantage of the 5 journals.
Time has a way of changing things. Companies go in and out of business. What was available a few years ago have disappeared from the planet. If you like something and have the money for it, buy it now.
04-19-2024, 07:50 AM | #10 |
The blanks are not hard to make
The drive gear is a little tricky but not impossible The biggest challenge is getting the basic profiles for the lobes done, heat treated and final finish. J
As Carroll Smith wrote; All Failures are Human in Origin. |
04-19-2024, 09:12 PM | #11 |
For Model A shocks I know they're not a stock shock but the Roto Shim lever shocks made in England are a great product.They have bolt on lever shocks that go right on a Model A or 32. They are accurate in size and unless your going for a high end restoration they are perfect. Check rotoshim.com Beats chasing Stipes. I'm not an A guy but Miller High Speed Heads seems to do a lot with A motors.
04-20-2024, 01:04 AM | #12 |
Roto shim lever shocks FYI: https://rotoshim.com/technical
04-21-2024, 12:47 PM | #13 |
Bill can sometimes be found on Facebook.
04-22-2024, 10:50 AM | #14 |
I'm on my third set of Rotoshim shocks. Because I now have them on all my cars...
Couldn't recommend them more highly. |
