As I look through online catalogs on running boards, it appears that replacement running boards are separate pieces from the splash apron.
The running board and splash apron on my car are formed from a single sheet. Were the the originals separate parts or one piece? |
#2 | |
Originals were two pieces
I'm confused, I think I read the statement differently than Brent. Car Pit, are you saying that your running board and splash aprons are all one piece together/no bolts, or that the splash apron is one piece instead of two?
Wanted: Simmons Super Power Head ![]() Craig Likon 1931 150B |
The apron and the running board are one piece. The attached photo is the best I have to show.
If you crawl up under the running board there will be a flange where the board and apron are flanged together. Not one piece. The two piece apron and the running board make 3 separate pieces.
All the major suppliers (Bratton's, Snyder's, etc.) sell the 1930 running boards with the splash apron attached to it.
Wow, Randy you are correct, they(I checked online) sell the 30's with or without the running board spotwelded on. I like it when I learn sumtin!
#10 | |
Today I learned that I'm s'posed to turn off the oxygen valve FIRST after welding!! GEEZ! I'm gonna' miss that "POP"!!!!! Bill W.
turn off the oxygen last as it cleans the tip.
#13 | |
I also contribute a damn lot of good proven advice & helps-------------Bill W. By the way, I didn't "hijack" the thread, I was commenting on another poster saying he learned something NEW today!
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 01-23-2013 at 12:37 AM. |
#14 |
#15 | |
I read in the genuine VICTOR welding manual that turning the gas off first usually causes a pop that can back up soot & carbon in the mixing chambers & is tough on the large & the small "O" rings where the tip or the cutting head seals to the mixing body. (Buster just said, "SO THERE!) If it makes you feel better, I've always done it BASSACKWARDS in my mixed & colorful past. Gotta' read more! LOL Bill W.
#16 |
Not trying to hijack the thread or anything but i was always told the bottle would explode if you turned off the oxygen last. Not that anyone can afford to weld with gas these days with bottle hire costing more than the gas.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
#17 |
I think there is some confusion in this. Yes, the majority of the 1930's had a body apron that WAS attached to the running board. It was one-piece. The corresponding fender originally had a short apron that was spot welded onto the fender flange making it one-piece too. Below are some pictures from different projects that hopefully will make this more clear.
#18 | |
Yes, 1930 passenger models had running boards formed integral with the main body of the running board shield until late September 1930. These have never been reproduced. Replacements made of two pieces are available. I hope they are better than the ones made 30 years ago as those were quite bad dimensionally. The one in your photo appears very restorable. That would certainly be my choice.
http://www.abarnyard.com/ |
#19 |
So I just learnt sumtin new to.
Was '30 the only year that this was done. |
#20 |
Yes, my intent is to work with what I have, especially if it is original. I ask because there are other signs of mismatched parts on the car that I randomly learn about, like the headlight bar is for a '29, not a '30.
