Old 11-28-2011, 12:13 PM   #1
spinelll
spinelll's Avatar
Default What to pay for a double A
I was thinking about buying an AA. I'm somewhat savvy with Model A prices but not these trucks. Assuming the drive train and brakes are in decent shape and then based on these few pics, can you guys give me a price range for this baby?
Thanks
spinelll is offline   Reply With Quote
Old 11-28-2011, 01:11 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: What to pay for a double A
Ohh I dunno, ....maybe one side or the other of $7,500.00. There really is so much else that should be factored in when making this kind of appraisal decision. We cannot see the interior, nor can I see details of the engine (type carburetor, fuel line, coil, etc.) nor can I really see body sheetmetal condition.
I do know that if it were mine I would drive it often ....after I first removed that stone guard!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-28-2011, 01:13 PM   #3
Mike
Mike's Avatar
I agree it is probably worth 6500.00 to 8000.00 I would offer him 6,000.00 and go from there
mike
Mike is offline   Reply With Quote
Old 11-28-2011, 01:14 PM   #4
CarlG
CarlG's Avatar
Interesting that it has bright headlight buckets, but a black radiator shell. My PU is just the opposite. I agree with Brent on the Stone Guard!
Old 11-28-2011, 04:10 PM   #5
darrylkmc
darrylkmc's Avatar
I have a Model AA Flatbed myself which I obtained more than twenty years ago.
Before I shelled out Six or Eight thousand dollars for a AA I would want to know a heck of a lot more about it.
Is it 131-1/2" wheelbase or 157"? 157" models are less desirable.
What is the condition of the Rims, Split Rings and Tires. You can tie up a lot of money on the wheels alone.
Does it have all 5 or 7 Rims?
What about the bed, is it original to the truck. The Stakes don't look original.
Often the back of the cab bottom is fatigued and rusted along with the front bottom cowl sections.
If you have to do Transmission work you have about a 30% chance that the case is rebuildable, they usually had a very hard life. Also U-Joints are spendy.
What about the Radiator, is it a 4 Core AA unit or one out of a car.
It has a nice late '31 front bumper.
More photos would be helpful.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 11-28-2011, 04:13 PM   #6
V4F
V4F's Avatar
ive seen them for 2k& up.
V4f
V4F is offline   Reply With Quote
Old 11-28-2011, 07:00 PM   #7
Tom H.
Tom H.'s Avatar
I agree with Darryl. Also if you are lucky and have the Hi-Speed rear axle, you will top out at about 43 mph. Low speed about 33.
Tom H.
Rear fenders and running boards for 1932 131" single wheel Express Body needed.
Tom H. is offline   Reply With Quote
Old 11-28-2011, 07:09 PM   #8
buyitsmart
buyitsmart's Avatar
Speaking of AA. Does that mean the engine number starts with AA? My 31 Deluxe Coupe has engine #AA2560452. I can't figure out what it came out of, but I doubt it was the original for my 31.
buyitsmart is offline   Reply With Quote
Old 11-28-2011, 07:26 PM   #9
darrylkmc
darrylkmc's Avatar
buyitsmart
Engines with AA designation were originally in a AA Truck chassis. It identified the engine as having a heavy duty clutch. The engine itself is identical to the Model A car engine.
I believe all car engines were stamped *A, however not all AA engines were stamped with a *AA engine number.
Darryl in Fairbanks
Old 11-28-2011, 07:43 PM   #10
2935ford
2935ford's Avatar
Is the cab bigger than a pickup?
2935ford is offline   Reply With Quote
Old 11-28-2011, 07:49 PM   #11
darrylkmc
darrylkmc's Avatar
2935ford
AA Cabs are the same as Model A Pickup cabs.
Darryl in Fairbanks
Old 11-29-2011, 10:09 AM   #12
rollingsculpture
rollingsculpture's Avatar
that truck looks like a resto in the last 10 years so you could figure it may have been gone through, looks like some cared about it enough to try to get all the parts back on it , although not all correct as noted light buckets front and back should be painted shells also the rear view mirrors are not originals, looks like the wood on the bed is plywood so its value is diminished , ive been putting together my own aa for the past 3 years and am finally enjoying the fruits of the labor , they dont go fast are are heavy vehicles i can keep up with traffic at 40mphs and have been up to once 50 mph on the flat long road but much over 45 and you have to be concerned its an old worn engine but keeps up fine.
Rust and roll will never die
rollingsculpture is offline   Reply With Quote
Old 11-29-2011, 10:30 AM   #13
Gumpy
Gumpy's Avatar
I would have an A expert inspect it...maybe compression ,the frame and brakes...Has it been sitting long and is there a fuel filter on engine...open gas tank and smell the fuel...any rust or condensation.....you could always ask the seller what he wants for it but there may be a few things that need attention the seller is unaware of...regards Gump
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 11-29-2011, 04:27 PM   #14
Tom H.
Tom H.'s Avatar
Looking good there Rollingsculpture.
Tom H
