Old 06-14-2011, 10:25 PM   #1
mrtexas
mrtexas's Avatar
Default putting the 29 back together
Does the headlight bar install with rubber pads at each end or is that someone's idea of an improvement?
I assume if I put those things on there I'll have to shorten the headlight bar as I don't recall taking any off when I took it apart?
mrtexas is offline   Reply With Quote
Old 06-14-2011, 11:23 PM   #2
Milton
Milton's Avatar
Default Re: putting the 29 back together
Nope, the bar will be fine and the fenders and brackets will just relax back to normal. If the bar wants to argue us l o n g carriage bolts to pull it together close enough to switch to stock bolts. This info is based on a 1930 and should be the same for a 29.
Milton is offline   Reply With Quote
Old 06-14-2011, 11:38 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
The rubber pads are not an original Ford part.
Old 06-14-2011, 11:59 PM   #4
Milton
Milton's Avatar
Aha, I feel enlightenment coming. Was anything used under the light bar? If yes, what material was used? If no, then great because they were a pain anyway.
Old 06-15-2011, 12:02 AM   #5
Tom Wesenberg
Nothing was used, and that may lead to a better ground for the lights.
Old 06-15-2011, 06:35 AM   #6
Great Lakes Greg
Great Lakes Greg's Avatar
Doesn't seem right, does it? Nothing under the tail light bracket, door handles or spare tire bracket either. Just bolt to that nice, shiney new paint. Really bothers me, but that's the way it is..
Great Lakes Greg is offline   Reply With Quote
Old 06-15-2011, 06:52 AM   #7
Tom Wesenberg
My 29 Tudor has thin pads under the 2 door handles.
Old 06-15-2011, 10:31 AM   #8
CarlG
CarlG's Avatar
I thought I read in the new JS as I was installing the new pages last night that the 31's had the rubber pads.
Old 06-15-2011, 11:21 AM   #9
Tom Wesenberg
I was refering to the 29 in question, but will have to check my new standards to see what they say about the 31's. Thanks, Tom
Old 06-15-2011, 11:50 AM   #10
Marco Tahtaras
Marco Tahtaras's Avatar
It shouldn't say that. I'm guessing you saw something else.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 06-15-2011, 12:02 PM   #11
glenn in camino
glenn in camino's Avatar
The door handles have a black paper pad to protect the paint.
Old 06-19-2011, 06:50 PM   #12
Milton
Milton's Avatar
Thanks Tom, I have replaced the rubber pads on the 31 and they now match your specification... "nothing". Besides, it looks better than those ill fitting pads from Vintique. Next removal will be on the 30.
Old 06-19-2011, 09:38 PM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
When I got my'29 coupe, it had a 1/8 inch RED rubber pad under the spare tire mount!! Nice fit. I just blacked it out with a Magic-Marker.
"THE ASSISTANT GURU OF STUFF"
