putting the 29 back together Does the headlight bar install with rubber pads at each end or is that someone's idea of an improvement?
I assume if I put those things on there I'll have to shorten the headlight bar as I don't recall taking any off when I took it apart? |
Re: putting the 29 back together Nope, the bar will be fine and the fenders and brackets will just relax back to normal. If the bar wants to argue us l o n g carriage bolts to pull it together close enough to switch to stock bolts. This info is based on a 1930 and should be the same for a 29.
Re: putting the 29 back together The rubber pads are not an original Ford part.
Re: putting the 29 back together Quote:
Re: putting the 29 back together Doesn't seem right, does it? Nothing under the tail light bracket, door handles or spare tire bracket either. Just bolt to that nice, shiney new paint. Really bothers me, but that's the way it is..
Re: putting the 29 back together The door handles have a black paper pad to protect the paint.
