Old 10-30-2024, 12:41 PM   #1
raj4851
Default Running Board Dihlemma
I ordered some running boards & covers some time ago. Come to find out, they are about 1/4 of an inch longer than my originals and the outer edge is 'way too long and has a lip on them. I've been trying to get them to the right dimension but it's a struggle. I got them from eBay from a "Moos", I think. I'm torn between trying to tweek these or find some quality boards. any suggestions? Thanks in advance. Rod.
raj4851 is offline   Reply With Quote
Old 10-30-2024, 12:47 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Running Board Dihlemma
Some information on the year and model of V8 Ford you are needing running boards for would be helpful.
Old 10-30-2024, 01:54 PM   #3
raj4851
Wow, how could I?? 1939 standard sedan Sorry!!
Old 10-30-2024, 01:58 PM   #4
raj4851
Sorry, two door sedan
Old 10-30-2024, 02:16 PM   #5
Seth Swoboda
To summarize, the running boards you bought were not for a 1939 standard sedan? Are you able to post a photo of them so we can see what boards you have purchased? Then we might be able advise.
Old 10-30-2024, 02:48 PM   #6
TJ
TJ's Avatar
Have you asked the seller who is his supplier or who is the manufacturer? That may shed some light on the problem.
Old 10-30-2024, 03:11 PM   #7
Kube
Kube's Avatar
Are they believing they are too long because they don't fit between the fenders?
Did you measure these carefully against the old running boards?
If you are attempting to fit them between the fenders, um, you may very well have to loosen a fender or two, install the board and then tighten the fenders in the "new" place.
Old 10-30-2024, 04:33 PM   #8
raj4851
Thanks for all the constructive comments. I couldn't get ahold of the supplier. The boards are at least 1/4" too long. The main concern is that the outside lip is at least 3/8 to 7/16 longer than my originals. I have them shortened but I'm not sure what to do about the lip. I guess cut the board & add a piece behind to strengthen it. ????
Old 10-30-2024, 04:50 PM   #9
Seth Swoboda
I think a photo will show us if you have the correct running board to start with. Kube has good points in his post. If you can't post photos let us know. You can send them to a member here that will post them for you.
Old 10-30-2024, 05:07 PM   #10
DavidG
DavidG's Avatar
Deluxe boards, which aren't the same?
Old 10-30-2024, 06:22 PM   #11
TJ
TJ's Avatar
If you have a '39 standard it uses the same running boards as all the '37s and '38s, This information is from the V8 Club's '38-'39 book. This is a well researched book with the info from the Ford archives. If you do not have this book I would recommend you buy it from the Early Ford V-8 Club. www.earlyfordv8.org
Old 10-30-2024, 06:33 PM   #12
Kube
Kube's Avatar
To the original poster: We need better answers if you want great advice.
Are the fenders on the car?
Did you remove the old boards?
The new boards you believe are too long... exactly where are they too long? Overall? Just the outer lip?
You bought them on eBay. Okay. How about sharing the item number with us? We will look it up.
If you bought them from Classicparts4u on eBay, well, you got taken. Junk.
Photos do help.
Old 10-30-2024, 10:45 PM   #13
raj4851
Thank you, Seth, TJ, & Kube. I will try to learn how to post pictures. The overall length is too long by 1/4 inch or so. I couldn't get any info from the eBay seller, Moos. The original boards fit fine & it definitely is a standard model. I'll work on the picture thing & try to research the seller. Thanks to all.
Old 10-31-2024, 10:08 AM   #14
Planojc
Planojc's Avatar
Not sure if they are still available but years ago I replaced my 39 Std. boards with ones from Drake. Perfect fit.
Planojc is offline   Reply With Quote
Old 10-31-2024, 11:10 AM   #15
Bob C
Here's a link to MOOS on Epay.
https://www.ebay.com/itm/28516753692...ampid%3APL_CLK
Old 10-31-2024, 11:46 AM   #16
Karl Wescott
Karl Wescott's Avatar
Those running boards in the link are 1940 (and 1939 Deluxe), the vendor also lists the 1937-38 (and 1939 Standard). They are OK street rod boards intended to be painted and run without covers (they do not have the subtle arch front to back). Because they are intended to be painted and installed the manufacturer added the 1/4" front to back to compensate for the thickness of covers.
If you want stock style ribbed boards there are basically three options. Drake is still showing in stock their rubber covered steel boards $$$$. We make fiberglass boards with the stock rib pattern $$$. Find a pair of ORIGINAL steel boards (look for the vent hole pattern on the top of the boards) and use the covers you have.
Bottom line to me... OK product, wrong application.
Karl Wescott is offline   Reply With Quote
Old 10-31-2024, 12:18 PM   #17
ford38v8
ford38v8's Avatar
Karl is one of a select few on the Barn that you can depend on getting straight answers from every time, no BS, no opinion, no guesswork. If Karl posts and answer, you can take it to the bank.
Alan
