Old 05-29-2011, 09:25 PM   #1
48Ratfink
48Ratfink's Avatar
Default Running on one cyl!
I started My A today and just for the heck of it I popped off the two front plug wires, then pulled #3 wire. The only one firing was #4 and it just chugged away! Guess My timing is OK. By the way I shut it off before reinstalling the wires. So anyone else tried this?
48Ratfink is offline   Reply With Quote
Old 05-29-2011, 09:38 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Running on one cyl!
If you want to see how to really time a model A Go to my web site and then videos and then timing your model A. You'll enjoy it running on one cyl. and it does work I've done it. Enjoy,
www.whidbeymodelaclub.com
Old 05-29-2011, 09:46 PM   #3
48Ratfink
48Ratfink's Avatar
Thats the video that showed Me it worked!! Ole Tex has some great videos!
Old 05-30-2011, 08:44 AM   #4
Patrick L.
Patrick L.'s Avatar
You shut it down before reconnecting the strips ??!! Thats pretty tame.. Spice things up and hook them up while the motor is chugging along..
Old 05-30-2011, 08:53 AM   #5
Robert
In 1959 my Dad explained to me to never ever NOT ever touch the spark plug connectors on his Model A while the engine was running. Well---I was a very curious 7 year old. The next time my Dad had the hood open and the engine running I found out why to never ever NOT ever touch the spark plug connectors!!! Some things must be learned through "hands on" experience.
Robert is offline   Reply With Quote
Old 05-30-2011, 09:04 AM   #6
Peter J
Peter J's Avatar
What are the physics behind this? Long stroke vs. compression is assume? I tried once and could only shut down two.
Peter J is offline   Reply With Quote
Old 05-30-2011, 09:18 AM   #7
PC/SR
The physics of one cylinder and super low speed idle is the rotating mass of the flywheel and low compression.
PC/SR is offline   Reply With Quote
Old 05-30-2011, 04:06 PM   #8
Milton
Milton's Avatar
Conservation of Angular Momentum.
My boy is a touchy feely kinda guy so all I had to do was say "You see those flat copper strips on the ZAAPPPPPPP" he doesn't touch them anymore either.
Now that I have a 27 lb flywheel and increased compression, no more one cylinder demos.
Milton is offline   Reply With Quote
Old 05-30-2011, 06:38 PM   #9
Peter J
Peter J's Avatar
Conservation of angular momentum=heavy flywheel/low compression
Old 05-30-2011, 09:09 PM   #10
Milton
Milton's Avatar
Yep.
Old 05-31-2011, 11:05 AM   #11
Jason in TX
Jason in TX's Avatar
Yup. Same here.
That huge flywheel keeps the engine spinning.
I guess when you're trying to make that little banger faster, running on one cylinder becomes less of a priority!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 05-31-2011, 11:31 AM   #12
Clem Clement
Clem Clement's Avatar
I love to demonstrate one cylilnder ops. The event always draws a crowd. After showing off I ask for a Chebby owner to do the same(:>)
