Old 05-27-2024, 12:28 PM   #1
AM3334
Default Dash gauges 34 Tudor
Any company make replacement gauges to fit in the original opening on 34 Tudor? I know you can buy the whole cluster be I don’t want to cut up the dash. It is in such good shape. I think the 33 has the whole gauge set that comes out. The 34 is not like that. Thanks
AM3334 is offline   Reply With Quote
Old 05-27-2024, 01:14 PM   #2
Newc
Newc's Avatar
Default Re: Dash gauges 34 Tudor
gauges 33/34 are same mounting in dash. Newc
Newc is online now   Reply With Quote
Old 05-28-2024, 09:53 AM   #3
AM3334
My 34 Tudor is one solid piece. Has holes for individual dash gauges not one for a cluster insert.
Old 05-28-2024, 03:36 PM   #4
dean333
dean333's Avatar
Send a message via Yahoo to dean333
You said you wanted to keep the cluster, so just get gauges. As stated above, 33-34 gauges mount the same.
Tim Carlig
dean333 is online now   Reply With Quote
Old 05-28-2024, 08:20 PM   #5
AM3334
There is no cluster. Just individual gauges.
Old 05-28-2024, 08:26 PM   #6
dean333
dean333's Avatar
So you don’t have the engine turned panel that the gauges fit into?
Tim Carlig
Old 05-28-2024, 10:27 PM   #7
AM3334
Yes that is correct. Each gauge has its own hole in one piece dash.
Old 05-29-2024, 12:40 AM   #8
BlueNotes
As you probably know is Classic Instruments selling a complete 1933 cluster. Have you asked them about the possibility to buy the individual gauges instead of the complete cluster?
I believe that the market for selling (modern 12V) individual 1933-34 gauges is much bigger than the market for complete 1933 clusters that requires the 1934 car customers to cut up their dashes if they want to upgrade to modern replacement gauges.
BlueNotes is offline   Reply With Quote
