The Ford Barn
-   -   Dash gauges 34 Tudor (https://www.fordbarn.com/forum/showthread.php?t=338922)
AM3334 05-27-2024 12:28 PM
Any company make replacement gauges to fit in the original opening on 34 Tudor? I know you can buy the whole cluster be I don’t want to cut up the dash. It is in such good shape. I think the 33 has the whole gauge set that comes out. The 34 is not like that. Thanks
Newc 05-27-2024 01:14 PM
Re: Dash gauges 34 Tudor
gauges 33/34 are same mounting in dash. Newc
AM3334 05-28-2024 09:53 AM
My 34 Tudor is one solid piece. Has holes for individual dash gauges not one for a cluster insert.
dean333 05-28-2024 03:36 PM
You said you wanted to keep the cluster, so just get gauges. As stated above, 33-34 gauges mount the same.
AM3334 05-28-2024 08:20 PM
There is no cluster. Just individual gauges.
dean333 05-28-2024 08:26 PM
So you don’t have the engine turned panel that the gauges fit into?
AM3334 05-28-2024 10:27 PM
Yes that is correct. Each gauge has its own hole in one piece dash.
BlueNotes 05-29-2024 12:40 AM
As you probably know is Classic Instruments selling a complete 1933 cluster. Have you asked them about the possibility to buy the individual gauges instead of the complete cluster?
I believe that the market for selling (modern 12V) individual 1933-34 gauges is much bigger than the market for complete 1933 clusters that requires the 1934 car customers to cut up their dashes if they want to upgrade to modern replacement gauges.
