After dropping my engine oil, I thought I would see just where the new added oil was on the Oil Level Indicator (OLI) (Dip Stick) after the addition of 1, 2, 3, 4 and 4.5 qts. There is approximatly 1/2 QT of oil left in the engine after an oil change...The engine takes 5 QT's.
Since there were two known OLI's, I thought I would measure each one (I used original Ford Model A/AA indicators). So here are the measurements in USA Qts and inches. 1928 Bayonett style: 1QT...1/2" 2QT...1" 3QT...1-3/4" 4QT...2-1/4" (Right at the lower line in the F) 4.5QT...2-1/2" 1929-1931 style: 1QT...No Show 2QT...3/8" 3QT...7/8" 4QT...1-1/2" 4.5QT...1-3/4" (Right at the upper line of the F) Providing all OLI are the same, this will tell you about just where and how much oil is in your engine. Pluck Last edited by Steve Plucker; 08-20-2015 at 04:38 AM. |
#2 | |
![]() Quote:
1 imperial gallon is 4.54 litres 1 US gallon is 3.63 litres.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
I have an older style dipstick in a 1930 block. 5 quarts puts it right on the full line. I assumed the part sticking in the block was the same on both dipstick styles. I guess not.
For such a simple car, I seem to be learning something new every week. ![]()
kris |
#4 | |
![]() Quote:
Pluck |
#7 | |
![]() Quote:
Pluck |
Thanks Steve this good to know
US Quart = 0.946353 Litres |
#9 | |
![]() Quote:
Make sure you use original Ford indicators if you do this test. Pluck |
I think this also depends on how much crud [ technical term] is laying around in the pan.
Because one never knows whether the dipstick is correct, once the pan is clean, I dump in 4 qts and mark the stick [ a slight hacksaw slash] and do the same after adding the 5th. |
Steve, It won't take much to convert your quarts into litres and your inches into centimetres. From the shape of the sides of the sump, a linear interpolation or extrapolation will be close enough. Thanks for the incentive to look at this.
The problem I can see here is that you have measured from the bottom up. If you measure from the top down, this will be a truer reading, as the dipstick hole is a constant datum point. Measuring from the bottom up, does not allow for varying stick lengths. I have several dipsticks of the same style, and I would be lucky to have three the same length from the bottom of the handle to the bottom of the stick. When I line them up, with the bottom of the handles all lined up, the full mark also lines up.
#13 |
#14 |
You can tell if there is a significant amount of sediment (AKA crud) in the bottom of the oil pan by:
1. Observing what is in the oil the drain plug which is shaped like a cup; 2. Probing through the drain plug hole with your index finger or a piece of coat hangar; 3. On 1928 & early 1929 engines, remove the oil pump cover plate from the pan and look inside with a small mirror and flashlight. My expectation is that engines running with an obsolete single viscosity non-detergent oil will have some crud. 1 Qt = 0.95 Liters 2 Qt = 1.9 Liters 3 Qt = 2.85 Liters 4 Qt = 3.8 Liters 4.5 Qt = 4.28 Liters 5 Qt = 4.75 Liters
Bob Bidonde Last edited by Bob Bidonde; 08-20-2015 at 07:39 AM. |
#15 |
hmmmm , I just count the empties on the floor . works for me ..........
V4f |
#16 | |
![]() Quote:
#17 |
I have a 1930 engine. My dipstick measures 2-3/8" from the bottom to the top horizontal line of the "F". Wrong dipstick for this engine?
#18 |
#19 |
Thought down in Oz you measure in litres?
#20 |
