The Ford Barn
-   -   Knowing the amount of oil in your engine... (https://www.fordbarn.com/forum/showthread.php?t=176188)
Steve Plucker 08-19-2015 08:57 PM
After dropping my engine oil, I thought I would see just where the new added oil was on the Oil Level Indicator (OLI) (Dip Stick) after the addition of 1, 2, 3, 4 and 4.5 qts. There is approximatly 1/2 QT of oil left in the engine after an oil change...The engine takes 5 QT's.
Since there were two known OLI's, I thought I would measure each one (I used original Ford Model A/AA indicators).
So here are the measurements in USA Qts and inches.
1928 Bayonett style:
1QT...1/2"
2QT...1"
3QT...1-3/4"
4QT...2-1/4" (Right at the lower line in the F)
4.5QT...2-1/2"
1929-1931 style:
1QT...No Show
2QT...3/8"
3QT...7/8"
4QT...1-1/2"
4.5QT...1-3/4" (Right at the upper line of the F)
Providing all OLI are the same, this will tell you about just where and how much oil is in your engine.
Pluck
Synchro909 08-19-2015 09:12 PM
Re: Knowing the amount of oil in your engine...
Since there were two known OLI's, I thought I would measure each one.
So here are the measurements.
1QT...1/2"
2QT...1"
3QT...1-3/4"
4.5QT...2-1/2"
1929-1931 style:
1QT...No Show
2QT...3/8"
3QT...7/8"
4QT...1-1/2"
Pluck
Providing also that all Quarts are the same too. The American quart is smaller than the imperial quart by 20%. I guess we will have to do some converting to figure out how many litres all this is.
1 imperial gallon is 4.54 litres
1 US gallon is 3.63 litres.
diomed 08-19-2015 10:42 PM
I have an older style dipstick in a 1930 block. 5 quarts puts it right on the full line. I assumed the part sticking in the block was the same on both dipstick styles. I guess not.
For such a simple car, I seem to be learning something new every week. :)
Steve Plucker 08-19-2015 10:46 PM
Right you are.
Pluck
Mad Mac 08-20-2015 12:05 AM
That's why we should all talk the same language. The world is going the litres way.
marc silva 08-20-2015 01:17 AM
My 28 has the bayonett dip stick. It has 2 lines on it. I have been told to run the oil level at the lower line and that the upper line must have been added at one time. I have seen other dip sticks with one line equal to the lower line. is it correct with 2 lines? I guess I should change my oil and put 4.5 quarts in and look at the dip stick. I never look until I drive it for a while..it uses so much oil I never pay much attention.
Steve Plucker 08-20-2015 02:31 AM
No lines on mine...just F and L.
Pluck
colin1928 08-20-2015 04:00 AM
Thanks Steve this good to know
US Quart = 0.946353 Litres
Steve Plucker 08-20-2015 04:42 AM
Just do the same test but in litres!
Make sure you use original Ford indicators if you do this test.
Pluck
Patrick L. 08-20-2015 05:23 AM
I think this also depends on how much crud [ technical term] is laying around in the pan.
Because one never knows whether the dipstick is correct, once the pan is clean, I dump in 4 qts and mark the stick [ a slight hacksaw slash] and do the same after adding the 5th.
Synchro909 08-20-2015 05:29 AM
Pluck
Steve, It won't take much to convert your quarts into litres and your inches into centimetres. From the shape of the sides of the sump, a linear interpolation or extrapolation will be close enough. Thanks for the incentive to look at this.
dave in australia 08-20-2015 05:58 AM
The problem I can see here is that you have measured from the bottom up. If you measure from the top down, this will be a truer reading, as the dipstick hole is a constant datum point. Measuring from the bottom up, does not allow for varying stick lengths. I have several dipsticks of the same style, and I would be lucky to have three the same length from the bottom of the handle to the bottom of the stick. When I line them up, with the bottom of the handles all lined up, the full mark also lines up.
bunnyc 08-20-2015 07:10 AM
Excellent point. I agree.
Bob Bidonde 08-20-2015 07:26 AM
You can tell if there is a significant amount of sediment (AKA crud) in the bottom of the oil pan by:
1. Observing what is in the oil the drain plug which is shaped like a cup;
2. Probing through the drain plug hole with your index finger or a piece of coat hangar;
3. On 1928 & early 1929 engines, remove the oil pump cover plate from the pan and look inside with a small mirror and flashlight.
My expectation is that engines running with an obsolete single viscosity non-detergent oil will have some crud.
1 Qt = 0.95 Liters
2 Qt = 1.9 Liters
3 Qt = 2.85 Liters
4 Qt = 3.8 Liters
4.5 Qt = 4.28 Liters
5 Qt = 4.75 Liters
V4F 08-20-2015 08:25 AM
hmmmm , I just count the empties on the floor . works for me ..........
katy 08-20-2015 10:30 AM
Actually it's only 16% smaller. The problem is that US fluid ounces and Imperial fluid ounces are also different sizes. The US ounce is lightly larger than the Imperial ounce.
bunnyc 08-20-2015 03:35 PM
I have a 1930 engine. My dipstick measures 2-3/8" from the bottom to the top horizontal line of the "F". Wrong dipstick for this engine?
http://www.fordbarn.com/forum/pictur...ictureid=32311
Patrick L. 08-20-2015 04:03 PM
What does it show after the oil change ?
mrtexas 08-20-2015 06:21 PM
Thought down in Oz you measure in litres?
That is a 28 dipstick.
