11-28-2012, 01:10 PM | #1 |
Banjo ring and pionion numbers
Ha Guys and Gals,
Got a truck banjo rearend that is apart,but I can't turn the pinion to count the teeth. However the ring gear has 37. What ratio would this be? Thanks John
1st. Cav Trooper Operation Garry Owen F Troop 9th Cav'71-'72 |
11-28-2012, 01:31 PM | #2 |
Re: Banjo ring and pionion numbers
4.11 - you divide by 9 as the number should read 9:37 (or is it 37:9?).
11-28-2012, 03:26 PM | #3 |
I believe its 9:37
11-29-2012, 02:35 AM | #4 |
Alan |
