05-09-2010, 08:16 PM | #1 |
40 Distributor rotor
In rebuilding my 40 distributor, it looks like a rather large gap between the rotor tabs and the cap tabs. What should the gap between the rotor tabs and the distributor cap tabs be?
05-09-2010, 08:24 PM | #2 |
Re: 40 Distributor rotor
As close as possible with out hitting the inner cap points,i would say between .020 and .040 should be ok. ken ct.
05-09-2010, 08:26 PM | #3 |
Thanks Ken
05-10-2010, 09:14 AM | #4 |
Is your gap directly opposite the contacts or off set side ways to the contact? There are two version contact caps, 32-36 and 37-41 the contact cap spacing is different and they do not index 32-6 spacing is 1" , 37-41 is 1 1/8"
dickspadaro.com |
05-10-2010, 10:08 AM | #5 |
Dick is correct. I am attaching a pic that shows both versions. The 68-12116 inner plate is correct for the 1937-41 distributors.
http://www.vanpeltsales.com/FH_web/F.../12116caps.jpg
05-10-2010, 10:11 AM | #6 |
05-10-2010, 11:07 AM | #7 |
There are no specific gap for this that i know of,i assumed you had the correct caps as dick said.Older caps also for 37-41 are small diameter contact pins than 34-early 36 which are much fatter diam. also the spacing is diff. ken ct.
