Old 05-09-2010, 04:49 PM   #1
Kevin - Illinois
Kevin - Illinois's Avatar
Question Timing gear slides in & out
Just discovered my timing gear is sliding in & out on the cam. I can grab the gear and slide it in & out about 1/4". The nut is tight and it's like the entire cam is sliding in & out. Is this normal?
Kevin - Illinois is offline   Reply With Quote
Old 05-09-2010, 05:17 PM   #2
JEC
Default Re: Timing gear slides in & out
The cam is held in place by the cover.
How in the world did you get your mother to crawl under the car like that?
JEC is offline   Reply With Quote
Old 05-09-2010, 05:18 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
No, not normal. The spring and plunger is stuck in, or the spring is weak or broken. You'll have to remove the cover in front of the timing gear. To do this, you'll need to support the engine by the oil pan.
Old 05-09-2010, 06:08 PM   #4
Kevin - Illinois
I already have the cover off. Are you saying that the in & out movement is normal and the only reason I'm seeing it is because the cover - pin & spring would normally hold it in place?
Old 05-09-2010, 06:20 PM   #5
James Rogers
James Rogers's Avatar
The cam will move some in and out with the cover off but not much. 1/4" is about the limit. It will twist as it moves in and out because of the helical cut in the dist drive and the timing gears.
Old 05-09-2010, 06:35 PM   #6
Kevin - Illinois
Thanks James!!!
