Old 03-27-2012, 11:23 PM   #1
rick55
rick55's Avatar
Default Easy picture posting
Ole Don asked for someone to show him how to post pictures.
This is the easiest way I have found.
I use Photobucket to post pictures on this forum, the HAMB and yblocksforever.
I simply past the image code straight into the reply by the following steps.
First open my album.
Then select the photo I want
Then click on the chain link on the top
This brings up this drop down box. Then simply tap on the image code line and a message will come up that image code is copied to clipboard. Click OK, then when and where you want to enter the picture, hit return on your keyboard to bring a new line, right click your mouse and click paste. This will enter the image code into your reply and when you hit save on the post it will then load the pictures into your post and you should see your handiwork.
Don't forget to hit return a few times to space your text above or below the image code. It looks better if you hit return after each photo as well, otherwise they end up joined together.
Hope this makes it easy to understand.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
