Old 05-09-2010, 10:08 AM   #1
marc hildebrant
marc hildebrant's Avatar
Default Transmission Fuilds
Group,
I have seen in Les Andrews books a reference to the use of STP along with 600 W oil for the transmission in the Model A.
Does it help ?
What are the proportions to use ?
Regards,
Marc
marc hildebrant is offline   Reply With Quote
Old 05-09-2010, 01:19 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Transmission Fuilds
240 gear oil and STP 50 -50. Some use STP 100%.
Old 05-09-2010, 03:07 PM   #3
skip
Banned
Have you actually done the screw driver test with STP? Dip the smooth metal end into STP, you can not hold on to the sinking smooth shank of the screwdriver between your fingers. It is the same for the 600 W oil.
I just use that 600 W oil from Bratton's. It's not 600 wt but may be an oil used in steam engines when 'T's and 'A's were young.. Anyway the 'transmixer' works just fine for me, for a 'crash box'. Both up shift and down shift. I mean how much better can one lube this thing? Same oil used in the rear axle, and steering box. Two quarts will last you years. 1-1/2 pt needed for the 3-speed.
I don't need any Scientifically Treated Petroleum from Andy Granatelli's company. I only use these long chain carbon molecules when I'm assembling and building my churns prior to start up for the first time. Often on the race engine I'd pull the distributor and spin up the oil pump from Ed Pink's shop for oil pressure before making spark.
skip.
skip is offline   Reply With Quote
