Old 05-21-2011, 10:57 PM   #1
CA Victoria
CA Victoria's Avatar
Default Model A Brake upgrade?
Lots of talk about upgrading to hydraulic brakes on Model As.
Would it be feasable to upgrade to 35 ford mechanicals?
If so are there any blogs on this conversion?
CA Victoria is offline   Reply With Quote
Old 05-21-2011, 11:02 PM   #2
Roadster62
Roadster62's Avatar
Default Re: Model A Brake upgrade?
Check the Monthly Banger Meet thread over on the HAMB, chances are there are guys that have done it over there.
Roadster62 is offline   Reply With Quote
Old 05-21-2011, 11:27 PM   #3
BCCHOPIT
BCCHOPIT's Avatar
like this
in the pic is a model A push rod. you need to use the 35 push rod it has a cup on the end
I rebuild every thing with Flathead teds stuff
I also put 32 brake out back
you will have to flip side to get the brake rods to work (driver side to pass side)
and do a little grinding on the bones
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 05-21-2011, 11:33 PM   #4
BCCHOPIT
BCCHOPIT's Avatar
One more thing I had to make a 3/8 spacer to put behind the spindle bearing to space out the drum.
Old 05-22-2011, 12:50 AM   #5
Geo. H
There are about four of us here who have 35 front brakes on our Model A's. Problems are bearing spacing--Speedway and Snyder's sell spacer; and parts supply, especially the operating wedge. I don't know anyone who has tried to install 35 rear brakes.
Geo. H is offline   Reply With Quote
Old 05-22-2011, 02:37 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
It has been discussed here not that long ago. I think the feeling was if you feel that you just have to go to juice you should get a modern kit from the vendors as the cylinders in the 75 year old parts might not be up to snuff. Questions about single and dual master cylinders also came up.
Here is one of the many threads on the installation,
https://fordbarn.com/forum/showthread.php?t=32970
Old 05-22-2011, 07:39 AM   #7
Kevin in NJ
The best upgrade you can do is properly rebuild the brakes with all new parts, new drums, arched shoes an centered.
You have to do the same amount of work to put on ANY brake system on the A. If you are changing the system you have to think a lot more to proper engineer the system and not introduce more issues.
That being said, consider...
Going to later brakes is not that great unless you change your wheels too. The Model A brakes are really limited by the tires. Keeping the same wheels means you introduce two problems. More brake then the tire can handle and an unsupported wheel hub of the A wheel. The Model A wheel requires the drum to support the hub of the wheel. This will allow the wheel to flex with questionable results in the long term.
It still comes down to proper restoration. If you do not properly repair the whole brake system you will not have good brakes. Switching brakes systems is not a true answer. Yes, you will end up with better brakes and that is because you fixed some or all of the problems with the worn out stuff you took out. Then you have to ask what new problems have you introduced?
If you plan on going down the road to later brakes....
I suggest that you first look at the evolution of the brakes through to 1938. Late 36 Ford introduced a floating adjusting wedge so going to 35 is not the full answer if you were to go that way. Also look up the parts in the Green Book.
Kevin in NJ is offline   Reply With Quote
Old 05-22-2011, 08:09 AM   #8
BCCHOPIT
BCCHOPIT's Avatar
I had the 35s for the rear. It was going to be a lot more work.
Old 05-22-2011, 08:16 AM   #9
Mike
Mike's Avatar
Why not just restore the original brakes to factory specifications? worked for my 4 Model A's
mike
Mike is offline   Reply With Quote
Old 05-22-2011, 11:04 AM   #10
Jim Brierley
'35 brakes have the same width and diameter as hydraulics. One problem with them is they don't have seperate e-brake shoes, so you have to use the e-brake handle to actuate all 4 brakes, and then the stop light are on. I have them on the rear only, and they overpower the front (stock) brakes, will go to all 4 soon. If you put them only on the front you won't have the stop light problem, and seem to be a good choice.
Jim Brierley is offline   Reply With Quote
Old 05-22-2011, 11:08 AM   #11
JoeWay
JoeWay's Avatar
Jim, you could install a switch activated by the e-brake handle to open the brake light wire.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 05-22-2011, 04:04 PM   #12
BCCHOPIT
BCCHOPIT's Avatar
mike
When your model A can do over 70 and you pass cars on your way to work on little 2 lane roads you need to up grade your brakes
If you drive 45 on Sundays the stock brakes are more then enough.
Old 05-22-2011, 07:38 PM   #13
CA Victoria
Thank you all for your comments. The last post sound like the best barometer. There have been hundreds before me to think/do the same thing on these cars. I like to explore all of the options......I'm thankful for a website such as ford barn with so many great guys willing to share their opinions and experiences.........I can't imagine doing 70 in my 31 Victoria. My 35 PU with an 8BA a 65 shakes like a dog passing a peach pit!!!
Old 05-22-2011, 10:18 PM   #14
BCCHOPIT
BCCHOPIT's Avatar
[QUOTE=CA Victoria; My 35 PU with an 8BA a 65 shakes like a dog passing a peach pit!!![/QUOTE]
I have a Great Dane she only shakes when she passes one of my socks
Put some Coker Classics on your ride and it will drive like a new car.
I am running 16" wires and the cokers 550s up front and 750s in the rear.
If I would just put some real shocks on the car it would be like a sports car.
I get some wheel hope on the bumps in the corners
Old 05-22-2011, 10:47 PM   #15
CA Victoria
I did put coker classicss (6.50's) on and it was night and day difference. My shock are crummy....i'm going to put tubes up front and then 65 on our roads won't be so bad.
Old 06-12-2011, 10:45 PM   #16
BCCHOPIT
BCCHOPIT's Avatar
I took the A for a ride this week end and WOW the new brake set up worked out real nice.
Now I have to work on my brakes on my 94 chevy truck those brakes suck
I took my buddy for a ride and hit the brakes and his ass came off the seat.
I thought his head was going to hit the windshield. I tolled him brake check but he didn't hold on. He will next time
