04-23-2011, 06:34 AM | #1 |
Shutoff valve packing stuck
Removed my original '31 fuel shutoff valve from the tank and can't see how to get the old packing out to replace it. Is there a trick?
Thanks. (It drips slowly, tired off the coffee can on the floor board) |
04-23-2011, 06:57 AM | #2 |
Re: Shutoff valve packing stuck
If this is a late 1931 shutoff (under the hood) just loosen the gas valve pack nut and put a drift pin in the outlet (on the bottom) and push the valve out.
04-23-2011, 07:18 AM | #3 |
This car is an early 31 (Oct 30), valve is inside the car. Does the valve shaft pullout or unscrew? Pulling on it with fingers doesn't work.
04-23-2011, 07:23 AM | #4 |
Sometimes the packing is so tight that you will have to press or hammer the valve out. I had to use a dental pick to remove my packing when I lapped the valve.
04-27-2011, 03:01 PM | #5 |
Tom,
I built a small puller like one for a steering wheel and finally got it out. The fiber type packing was really tough. What are you using to lap it with? Any tricks to it? thanks |
04-27-2011, 03:04 PM | #6 |
04-27-2011, 03:34 PM | #7 |
It's been 10 years or more, but I seem to recall using my lathe and fine emmery cloth to polish the valve. I used toothpaste to seat the carb needed and seat and may have use some toothpaste on the shutoff valve also. Both have been great since then. I lost 10 gallons over the winter before the fix.
04-27-2011, 06:31 PM | #8 |
I used valve lapping compund and did it slowly by hand. Then cleaned everything real well before reassembly and it has worked great (no leaks) ever since.
07-05-2012, 08:40 PM | #9 |
My valve is the same inside the car early 31. The packing is fused in the housing. Can you pull on the shaft to loosen?
07-06-2012, 02:53 AM | #10 |
Bill's dentist died, so he doesn't get free dental picks anymore. Bill W's Ghost
