05-15-2024, 05:50 PM | #1 |
Model B Block Boss on side of block
Some Model B motors have a boss on the side below the water neck. What is it for, what is the story of it? |
05-15-2024, 09:12 PM | #2 |
Re: Model B Block Boss on side of block
Ford engineers were developing a vacuum assisted clutch and this was where the vacuum cylinder mounted. The unit never made it to production but a lot of motors were produced with this boss. The unit picked up vacuum from the intake manifold and the early manifolds had a large port in the front. This large port was used for the vacuum windshield wiper for a lot of motors. Attached is a picture of the manifold. First picture has the large port in the front and the second picture is a later manifold without.
Charlie Stephens |
05-15-2024, 11:27 PM | #3 |
Thank you!
05-16-2024, 12:20 AM | #4 |
05-16-2024, 07:38 AM | #5 |
I've read about the vacuum clutch thing,but I don't know if any were built.I've never seen a picture anyway.This is the first time I've heard about vacuum assisted brakes,where could I find that info? (I like to study these oddball things)
05-16-2024, 08:35 AM | #6 | |
https://www.fordgarage.com/pages/Bintakevariation.htm As far as I know there never was vacuum assisted BRAKES. I have a diagram of clutch proposed setup on one of the computers at the shop or at the house. EDITED: turns out it was the Auto transmission I was thinking about see next post. Last edited by Benson; 05-16-2024 at 09:12 AM. |
05-16-2024, 09:02 AM | #7 |
There was an Automatic transmission that Cartwright CORP came out with in July 1931.
Also there was a vacuum assisted clutch that Bendix came out with. It is not clear if either one of these used the changes to the block discussed above. Last edited by Benson; 05-20-2024 at 08:37 AM. |
05-16-2024, 12:21 PM | #8 | |
05-16-2024, 06:11 PM | #9 |
I was aware of the vacuum assisted clutch (definitely clutch not brakes) but I did not know that had anything to do with the boss. Here is the picture showing all.
20240516_235909.jpg Thank you for your assistance |
05-16-2024, 06:40 PM | #10 |
Thank you for that picture but what is that thingy on the front of the engine near the generator? The switch on the starter looks to be backwards too.
I wonder whether a vacuum assisted clutch never went into production because the pedal and the cylinder would be on opposite sides of the car on a RHD car. Besides, there is no room for the cylinder on such a car because the steering column is already there.
05-16-2024, 06:53 PM | #11 |
Synchro,
The item you mention on the front of the engine behind the fan looks like a vibration damper/isolator. If you look closely, you can see two supports that run from it down to where the engine would mount to the frame. |
05-16-2024, 08:16 PM | #12 |
Thanks, I can see that now. Were they another thing that never went into production?
