03-03-2024, 03:46 PM | #1 |
46-48 gas tank questions
I picked up a 46-48 gas tank a while back and I'm getting it ready to clean it out.
-I put some heat on the drain plug and the outlet noticed what looked like little metal beads. Are these lead soldered? -it looks like there's a line in the tank that runs to the plate. Can that t taken off? -last question can I fill some pin holes with lead solder? |
03-03-2024, 06:36 PM | #2 |
Re: 46-48 gas tank questions
It’s just me, but I always leave gas tanks to people who do that for a living. I know that I surely don’t know how to safely apply heat/flame to a tank that may have residual fuel or vapors. Please be careful, and good luck with saving an original. My ‘46 tank had several dime sized holes in the top, so I bought a new Drake tank.
03-03-2024, 06:42 PM | #3 |
I had a friend that was grinding on a gas tank it exploded and he woke up in the corner of his garage!! Dont put a torch on a tank !! Dave
03-03-2024, 07:06 PM | #4 | |
You may or may not be able to solder pin holes. The issue is, if you see some holes, there are a zillion more that are not seen and will show up sooner rather than later. I'd suggest buying a new tank from Drake. I am not a big fan of his but have to say, he got those tanks right. I have installed a couple in '46 - '48. The safety thing that has been brought up by others is quite real and should be taken very seriously. I don't know of any shops that will still repair these. The unleaded fuel has a way of permeating the metal and as such is much more dangerous than the tanks that were used with leaded fuels.
03-03-2024, 07:56 PM | #5 |
Gas tanks were made from terneplate which had zinc in it. That's probably causing the silver bubbles you saw.
03-03-2024, 08:12 PM | #6 |
03-04-2024, 08:21 AM | #7 |
To be clear, gas tanks were not made from terne but rather, were plated with terne.
The beads surrounding the bung where you had applied heat was solder.
03-05-2024, 10:57 AM | #8 |
Topher , you are one lucky guy that that tank did not cause you some great harm. As others have suggested buy a new tank. Trying to fix an old tank is a huge waste of money and if you use sealer in it and the sealer comes loose, you will start all over again.
03-05-2024, 02:49 PM | #9 |
no worries...this tank hasn't had gas in it for eons.
I really don't want to buy a new tank I already have two others from parts cars. LOL |
03-05-2024, 07:33 PM | #10 |
Thanks Kube for the "terne plate" info.
03-06-2024, 09:38 AM | #11 |
I seem to recall that once the plating is compromised, the tank rusts out rather rapidly.
