02-16-2024, 10:41 AM | #1 |
10" Ford Tractor pressure plate
I have a new 10" Ford tractor pressure plate. It is the Long style with adjusting bolts on the fingers. The dimensions are the same as the pressure plate I took out of my F1. It does not have counter weights on the levers. Can I use that on my 8BA? Will it cause a stiffer clutch pedal? Anybody use one of these?
02-16-2024, 11:42 AM | #2 |
Re: 10" Ford Tractor pressure plate
Those weights are not "counter weights", They are to provide more pressure to the disk by using the centrifugal force when spinning at high RPM.
I would not use it |
02-16-2024, 11:49 AM | #3 |
Why not? Just curious.
02-16-2024, 12:23 PM | #4 |
