01-30-2024, 09:40 PM | #1 |
mixing brake shoe linings
Anybody ever heard that mixing bonded and woven linings on a wheel gives a better brake?? I talked to a very knowledgeable Model A restorer and he claims that a woven front shoe and bonded rear shoe will give better braking. I never before heard of this. I know that the woven lining gives a softer pedal and the bonded lining gives a harder pedal. I don't know what the logic is for mixing linings or why it might give a better brake action. Curious to opinions of Ford Barners.
01-31-2024, 01:19 AM | #2 |
Re: mixing brake shoe linings
The only thing that I have heard of regarding the type of linings is that woven linings tend to work better on the original steel drums and the bonded linings work better on the cast drums ?
Never did any back to back testing to check though |
01-31-2024, 11:36 AM | #3 |
That is as I have heard also.
Ruth "Sometimes you really DO need to read the whole thread" |
01-31-2024, 11:38 AM | #4 |
It doesn't make sense. If adding one in place of the other lining type makes the brakes work better, wouldn't two of the same that made it better make it betterer? (as Derek Bieri would say)
01-31-2024, 11:40 AM | #5 |
I have two Model As, both with cast iron drums. One has bonded, one has woven. I can lock up the rear wheels on both. The one with the woven linings has a somewhat softer pedal feel. That's about the only difference I see.
01-31-2024, 04:06 PM | #6 |
02-01-2024, 04:47 AM | #7 |
With servo assist you have a smaller shoe to force the longer shoe into action. I assume the "unusual thought" is to re-create servo assist with a less functioning lining. Better off with Ted's floaters.
02-01-2024, 12:42 PM | #8 |
It is a myth that bonded linings work better than woven linings on cast iron brake drums.
Braking efficiency is totally dependent on the applied input force, the coefficient of friction of the brake linings, heat transfer / heat dissipation and the mechanical condition of the brakes. I have tried both linings on cast iron drums and I cannot tell the difference in stopping performance by the seat of my pants. However, the brake dust from the molded linings is too much to deal with if the car has light colored wheels. This indicates that the molded linings were wearing faster. I also found that bonded linings, when riveted to the shoes, have a tendency to crack at their attachment rivets. The only improvement of bonded linings over the woven linings is the precision the molded lining material can be arched to. I went back to woven linings with cast irons drums, and I am pleased with their braking performance. PS: I have Flathead Ted's Brake Floaters on my A's, and the improvement in braking is outstanding!
Bob Bidonde Last edited by Bob Bidonde; 02-02-2024 at 11:10 AM. |
02-01-2024, 07:54 PM | #9 |
The problem with bonded linings is making sure you get soft ones. Probably easier to get soft woven linings. Randy Goss has worked out where to get soft bonded linings.
