01-26-2024, 03:03 PM | #1 |
Donovan 4 Cylinder
Are there any of the Aluminum Donovan 4 cylinders or parts still available?
01-26-2024, 04:26 PM | #2 |
Re: Donovan 4 Cylinder
Found them still listed on Google. Checked out their site. Needed some smelling salts after I checked the 4 cylinder price list. Cost's a lot to fly first class.
01-26-2024, 05:08 PM | #3 |
After watching the TV show, "Air Disasters". would you still want to fly? LOL
01-26-2024, 06:29 PM | #4 |
Bring your big boy pants
Last year sourced one for inquiry Coming out of Sweden no less The Burtz is a deal J
As Carroll Smith wrote; All Failures are Human in Origin. |
01-26-2024, 07:13 PM | #5 |
I seem to recall the late Dennis Piranio used the aluminum blocks in his Bonneville cars. He set unbelievable speeds for that design.
01-26-2024, 08:19 PM | #6 |
SCTA and BNI do not allow any blocks not an original production pre’35 And yes the records are very impressive for 85 year old metal J
01-26-2024, 08:27 PM | #7 |
The Donovan was the hot ticket when it came out. Individual intake runners (IR), 5 bearing crank & cam, 4 bolt main caps, lightweight, pressure oiling. The Burtz only lacks the IR and 4 bolt mains but is heavier.
Here is the price list on their site. It's 2011 so you'll need to probably use the 100% post Covid price increase. If I had an unlimited budget and was chasing a record it would have to be the Donovan. Building a 100hp streetable toy the Burtz would be the way to go for ultimate reliability. But then a polished Donovan with a candy paint job would be a show stopper - even at SEMA. You could run it at Bville but not in the V4 class. I doubt you'd have much luck against a current 4V OHC 3.6 liter Japanese engine. V4 stands for vintage four-cylinder and designates pre-1935 four-cylinder engines up to 220 cubic inches. OHV and specialty heads are allowed. http://www.modelaparts.net/hiperf.html/donovansem.html https://qix.owj.mybluehost.me/wp-con.../05/ModelD.pdf Last edited by ModelA29; 01-26-2024 at 08:48 PM. |
01-26-2024, 10:52 PM | #8 |
Yes, the V4 regs are very detailed and competing in the open displacement classes are challenging.
Even with this sort of hardware it is difficult to compete against a modern architecture motor. John
01-27-2024, 07:29 PM | #9 |
The Burtz engine has pretty modern internal architecture yet looks the same as an original engine from the outside. How do the judges know what they are looking at?
01-27-2024, 10:10 PM | #10 |
No problem to tell, if record beaten you must drop its pants, same in any sport, I know you are cheating because im cheating & you are beating me ,
01-28-2024, 03:19 AM | #11 |
You can easily stick a borescope in the oil fill tube on the model A engine and see the crankshaft and the main bearings. You can easily see if it has a counter weighted crank and if it has more than 3 mains. You can buy these small borescope cameras that work with your iPhone for under $10.00 on eBay!
It’s time to work smarter not harder guys by using modern technology.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
01-28-2024, 04:01 AM | #12 | |
01-28-2024, 05:31 AM | #13 |
Probably referring to race scrutineers rather than concours judges. Competitors can protest that you have a modern block in a vintage class. I believe Bonneville record breakers have their motors cc'd to make sure they don't exceed the cu. in. limits of their class.
01-28-2024, 08:34 AM | #14 |
I just looked on Ebay for horoscope cameras. None for $10, but you can get semi rigid or soft wire. What do folks recommend buying?
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
01-28-2024, 12:21 PM | #15 |
You would be amused at some of the "improvements" attempted on V4 motors.
The SCTA-BNI site publishes a list of modifications allowed and not allowed, understand there is a reason this guide exists. J
01-28-2024, 01:29 PM | #16 |
Back in the early days of stock classes in drag racing, the cheaters would leave #1 cylinder cc's the allowable amount but bore all of the others larger, hoping the tech would check that cylinder for size using a volumn checker and leave the others alone.
01-28-2024, 03:31 PM | #17 |
The borescope I have is the Wi-Fi version for the iPhone. I bought it about six years ago it was under $10. You can also buy a direct cable one that plugs into your phone. Here’s a link to one that’s under $10.
https://www.ebay.com/itm/14388903797...mis&media=COPY
01-28-2024, 05:00 PM | #18 |
Current build, all new
Off to the dyno soon....
01-28-2024, 10:43 PM | #19 |
Beautiful engine!!!
01-28-2024, 11:03 PM | #20 |
