01-08-2024, 02:08 PM | #1 |
Fan Belt Slips Off
The fan belt on my Runabout keeps slipping off. I've tried tightening and loosening but still slips off. What is causing that?
01-08-2024, 02:42 PM | #2 |
Re: Fan Belt Slips Off
The pulleys need to be parallel and have a slight crown. Check carefully what you have.
01-08-2024, 06:49 PM | #3 |
I noticed a set screw on the water pump pulley. I will try adjusting it and see if it stays on better.
01-08-2024, 08:45 PM | #4 |
It might just be the photo angle, but are the centers of each pully in line?
01-08-2024, 09:27 PM | #5 |
I'll check the center alignment of the pulleys. I'm concerned about how close the belt is to the timer.
01-08-2024, 11:30 PM | #6 |
01-09-2024, 09:25 AM | #7 |
Try a straight edge on the outside flat surfaces of the pulleys. Make adjustments. JMHO
01-11-2024, 02:55 PM | #8 |
I have used these guides that just bolt to a timing cover bolt.
01-11-2024, 06:42 PM | #9 |
Location: North Warrandyte, Melbourne,Victoria, Australia
Try a slightly smaller ID belt ,
That way it's sits tightly in the groove, Also use CRC belt grip to help lubricate the belt. |
01-16-2024, 01:41 PM | #10 |
a Gates belt might slip less as well.
01-20-2024, 11:00 AM | #11 |
I removed the water pump and i'm seeing how things go. It leaked and I tried installing new packing with poor results. The belt slipping off problem is solved. I'll find out if my radiator is in good shape this summer if not before.
