12-21-2023, 05:40 PM | #1 |
Violent shake.
So to start with I have a 1950 Ford Custom. I have replaced the clutch, pressure plate, throw out bearing and hub. I had the flywheel resurfaced. It also has new u joints.
From a dead stop the car shakes hard. It smoothes out after the car gets moving. It's only on a start. I do hear a mechinacal sound some times when at speed. Any ideas? |
12-21-2023, 05:46 PM | #2 |
Re: Violent shake.
Have you checked all of your steering coponents for wear or anything that is loose? Drag link, tie rod ends, king pins?
12-21-2023, 06:04 PM | #3 |
Re: Violent shake.
King pins have been changed. No loose steering parts either.
12-21-2023, 06:08 PM | #4 |
Re: Violent shake.
Check the motor mounts (and the transmission mount while you're at it).
12-21-2023, 06:11 PM | #5 |
Re: Violent shake.
Are you talking about clutch chatter or is it after the clutch is fully released?
12-21-2023, 06:13 PM | #6 |
Re: Violent shake.
12-21-2023, 06:15 PM | #7 |
Re: Violent shake.
It happens just as the clutch engages the flywheel.
12-21-2023, 06:23 PM | #8 |
Re: Violent shake.
I was just thinking us it possible pinion angle could cause this?
12-21-2023, 06:25 PM | #9 |
Re: Violent shake.
Here’s an option.
Engine steady rods. |
12-21-2023, 06:32 PM | #10 |
Re: Violent shake.
Those steady rods won't fit a 1950 Ford.
12-21-2023, 07:12 PM | #11 |
Re: Violent shake.
Broken rear leaf on spring pack , loose or broken shackles, loose u bolts to axle housing .
Of course youve already checked the obvious clutch possibles . Trans mount and motor mounts or oil on the disc or a bad pressure plate . |
12-21-2023, 07:40 PM | #12 |
Re: Violent shake.
Did you have the shake prior to doing all this work?
12-21-2023, 08:21 PM | #13 |
Re: Violent shake.
Is there any play in the clutch pedal when it is all the way up? If not the clutch may not be fully engaging.
12-21-2023, 08:35 PM | #14 |
Re: Violent shake.
12-21-2023, 08:38 PM | #15 |
Re: Violent shake.
12-21-2023, 08:57 PM | #16 |
Re: Violent shake.
Terry, I read where you installed most all the New clutch parts,
but curious, did you install a New Pilot bearing/bushing too ? A wore out pilot bearing/bushing will cause one heck of a shake. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. |
12-21-2023, 09:02 PM | #17 |
Re: Violent shake.
I had the same issues in 1960 on my 50 Ford. I had the flywheel resurfaced. Should have had it balanced at the same time.
Bruce
Works good Lasts long time |
12-21-2023, 09:12 PM | #18 |
Re: Violent shake.
12-22-2023, 09:50 AM | #19 |
Re: Violent shake.
Tell us about the engine. Is it newly rebuilt or an older engine? Someone mentioned an oil soaked clutch and yes, that will cause a violent chatter when you let the clutch out. What is the surface of the flywheel like? Does it have hot spots?
12-22-2023, 10:08 AM | #20 | |
Re: Violent shake.
Earlier in this thread I mentioned pinion angle. Do you think that could cause a shake? |
