12-14-2023, 02:04 PM | #1 |
4 barrel intake
Will an 8ba intake fit on a 59a block ?
12-14-2023, 02:34 PM | #2 |
Re: 4 barrel intake
It will bolt on, but the crankcase ventilation will be backwards; probably best fixed with a properly installed PCV system.
12-15-2023, 12:32 PM | #3 |
Re: 4 barrel intake
This is done allot, ask a specific question and someone will will come up to help.
Gramps |
12-15-2023, 02:19 PM | #4 |
Re: 4 barrel intake
Other than the crankcase ventilation situation (which is a rather esoteric matter), any other problems are about the same as one would run into with any aftermarket manifold swap (linkage, fuel lines, etc.).
As Ron said, if you have any specific questions, I'm sure someone on here can answer them. |
12-15-2023, 03:47 PM | #5 | |
Re: 4 barrel intake
As said above, the late intake will bolt to early block, but the two blocks ('35 - '48 & '49 - '53 breathe/ventilate their crankcases completely differently. If you swap and do not modify correctly with a well thought out PCV system, at the very least you're likely to have severe oil leaks almost everywhere on the engine. The direction of ventilation for the two different engines BELOW. EARLY Engine Breathing LATE Engine Breathing BELOW is a link to a comprehensive piece I put together over four years ago with facts and ideas to build a PCV System on an 8BA with an EARLY Thickstun manifold. Good info, pictures and parts list. PLUS .... the ugly PCV Valve is hidden & easily serviceable. Click the link BELOW! https://www.fordbarn.com/forum/showt...take+8ba+block Coop . |
12-15-2023, 04:51 PM | #6 |
Re: 4 barrel intake
The air inlet needs to be at the back of the manifold on a 59AB and it also needs to have the 59AB rear baffle installed. With air entry at the rear of the manifold and no rear baffle, the inlet air just goes across the valley and exits wherever you have your PCV plumbed. If I am correct, the rear of a typical 8BA manifold is a different height than a 59AB - so in order to use the 59AB baffle, one would also need to resolve the fuel-pump mount surface height issue. |
12-15-2023, 05:07 PM | #7 | |
Re: 4 barrel intake
