11-15-2023, 10:32 PM | #1 |
Replacing studs on a rear spare tire mount
One of the studs holding the spare tire on the rear of my car is striped. How do I remove remove and replace both of them?
Thanks Dick
1965 Lotus Elan S2 1930 Model A Sport Coupe |
11-16-2023, 11:27 AM | #2 |
Re: Replacing studs on a rear spare tire mount
Are you talking about the studs on the carrier that the spare tire lug nuts screw onto? I believe they are simply pressed in. I'd use heat and penetrating fluid and a press to get them out.
11-16-2023, 04:48 PM | #3 |
There are several versions but where the spare bolts on they used a carriage type bolt that fit into the punched square holes. They have a special head on those bolts and they were likely a tight fit to the carrier. I can't tell if they were swaged or not. One of the holes cracked on mine so a previous owner has regulat dome head carriage bolts welded onto the carrier. Typical shade tree repair.
11-16-2023, 10:28 PM | #4 |
They do appear to be swedged. You need to remove the carrier and use a press to remove it and then press a new one in.
Brian SATX |
11-17-2023, 06:59 PM | #5 |
