10-30-2023, 12:58 PM | #1 |
Why is emergency brake not working?
The emergency brake on my truck is not working.
When I push the plunger down and pull the handle back, the teeth are not catching. Are there any parts that seem to be on wrong? Thank you. Neil |
10-30-2023, 01:04 PM | #2 |
Re: Why is emergency brake not working?
Here are pictures.
10-30-2023, 01:07 PM | #3 |
Change the cotter pin, Neil. Kroil the toggle.
10-30-2023, 02:35 PM | #4 |
looks like pawl may be a little rounded over?
www.whidbeymodelaclub.com |
10-30-2023, 02:49 PM | #5 |
When you ease the car down the driveway (5mph or so) and push in on the clutch does the e-brake stop the car?
10-30-2023, 06:46 PM | #6 |
If the handle parts work OK on your car, the problem lies in the rear, could be worn or grease polluted lining, rods out of adjustment, etc... |
10-30-2023, 08:40 PM | #7 |
delete
10-31-2023, 12:03 AM | #8 |
sounds like you have the wrong pawl installed on the ebrake lever
11-02-2023, 04:52 PM | #9 |
I believe that the sector with the teeth on it is installed backwards.
11-03-2023, 12:45 PM | #10 |
Interested-following
