08-25-2023, 12:49 PM | #1 |
1930 Rear Brake Drum Hub Type/Style
I'm looking for information on these two different styles of Model AA Rear hubs, why the difference ? See attached photos ....
Thanks Steve |
08-25-2023, 03:30 PM | #2 |
Re: 1930 Rear Brake Drum Hub Type/Style
I wonder if the one on the right ws used with the 1931 spoke wheel?
I guess not, the spoke wheel drum looks totally different. Last edited by Bob C; 08-25-2023 at 03:36 PM. Reason: corrrect information |
08-25-2023, 04:34 PM | #3 |
If you check the "Service Bulletins " you will see when the early AA " scalloped " hub on the new bevel gear rear axle was changed . This early hub was causing wheel hub area failure with heavy loading . A stiffening plate was issued in service to prevent failure . Your pictures show both early and late styles .
John in West Drayton London sunshine and showers . |
08-26-2023, 12:06 PM | #4 |
Regards Steve |
