07-09-2023, 11:37 PM | #1 |
Widowmaker
We all know about the famous flying fan blade. This guy hangs it from his ceiling
07-09-2023, 11:58 PM | #2 |
Re: Widowmaker
Better the hood than the radiator I guess. Either one is not cheap.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed Last edited by stickshift; 07-10-2023 at 12:07 AM. |
07-10-2023, 05:55 AM | #3 |
Re: Widowmaker
New guys who do not believe old fans are dangerous should see this photo.
My Coupe has a 5 inch (3 sided) hole about 6 inches further up on the CURVED part of the hood where a blade went through it. Never did find the blade. I DO NOT want to think about what that would do to a person's head if they had their face in there while revving the engine! 60 years later I still move over "out of the line of fire" whenever someone is revving an engine! Last edited by Benson; 07-15-2023 at 11:24 PM. Reason: Updated info in Blue text |
07-10-2023, 06:23 AM | #4 |
Re: Widowmaker
Show & Tell Trophy |
07-10-2023, 06:29 AM | #5 |
Re: Widowmaker
Apparently, these Fan Blades come adrift more often that you might think. This one happened on the Model A Run in New Zealand this year. |
07-10-2023, 06:47 AM | #6 |
Re: Widowmaker
Marshall |
07-10-2023, 08:16 AM | #7 |
Re: Widowmaker
Is there a way to tell an original fan from a newer replacement?
07-10-2023, 08:17 AM | #8 |
Re: Widowmaker
07-10-2023, 08:32 AM | #9 |
Re: Widowmaker
Original fans are steel, new two blade fans are aluminum, if a magnet sticks it’s a steel original
07-10-2023, 09:23 AM | #10 |
Re: Widowmaker
45 years ago I also had a 4 blade V-8 fan rivets fail as Marshall says.
07-10-2023, 09:25 AM | #11 |
Re: Widowmaker
I've had the original two blade on the 31' for 60 years. Bought the new aluminum one a couple of years ago... you may have finally motivated me to do the swap.
Thanks Joe B |
07-10-2023, 09:30 AM | #12 |
Re: Widowmaker
IF THE FAN BLADE DOES THAT MUCH DAMAGE going through the hood just think for a minute what damage it will do to your face if the hood is up and out of the way!
07-10-2023, 09:35 AM | #13 |
Re: Widowmaker
The 31 fans are better beefer, when I changed out my 31 original for the new aluminum fan some of my vibrations when away !
07-10-2023, 09:35 AM | #14 |
Re: Widowmaker
IN 1930 OR 31 Ford came out with an improved 2 blade fan which is better BUT it stills fails the same way.
Besides if you have a 31 car who is to say that someone did not put an earlier fan on the water pump? "Ain't So ?" |
07-10-2023, 08:43 PM | #15 |
Re: Widowmaker
When I bought my first Model A, I knew nothing about this. When I found out, acting with an "abundance of caution", I checked it. It had been badly cracked, then brazed up and refitted at some time. It had cracked again so badly I didn't want to start the engine again till I fixed it. The cracks ran out along the blades and around the pulley and base of the blades. My first job on the "new" car was to get it running properly which involved
running and revving the engine while I was leaning over it. I consider myself EXTREMELY lucky to be alive. It gives me goose bumps to think of it!
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 07-11-2023 at 06:16 PM. |
07-11-2023, 07:38 AM | #16 |
Re: Widowmaker
Remember back in the late 70’s ford still had problems with fan blades going thru hoods and then killing somebody! I checked my mercury and it was missing a blade, no holes in the hood or radiator……… the window must have been opened when it departed! LOL
07-11-2023, 10:32 AM | #17 |
Re: Widowmaker
A group of us were coming back from a tour on Memorial Day when one of the Model As lost a fan blade. No damage to anything, never saw where it went. One of the guys just broke off the other side to balance it out and we proceeded at speed the rest of the way home. I think he's waiting until the aluminum two-blades become available to replace it.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
07-13-2023, 02:33 AM | #18 |
Re: Widowmaker
Yep,
There is a reason my hood is a slightly different color than the rest of the body........ New aluminum fans are way cheaper than a broken fan blade. |
07-13-2023, 06:45 AM | #19 |
Re: Widowmaker
It is not just the fan, I had an original generator pulley break apart while the motor was running. The hood was up and the pulley struck my garage wall. Check your moving, rotating parts carefully. They are like us, getting old and tired.
07-14-2023, 02:54 PM | #20 |
Re: Widowmaker
my hood has a dent in that spot and the radiator has been repaired in the past. I assume because of the same issue
