05-19-2023, 05:21 PM | #1 |
Cotter Key Plastic Box Information Needed
A few years ago someone posted a picture of a plastic compartment box about 6x4x1 inches and a table of all cotter keys used in a Model A. You put the table on top of the box. That made a good selection of the cotter keys. I put together one or two of these boxes to have and now I cannot find it or the table. Is there a better memory out there than mine and can you post the information? I would appreciate this.
Vic |
05-19-2023, 05:44 PM | #2 |
Re: Cotter Key Plastic Box Information Needed
Les andrews red book A-3 has them all listed
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:36 PM. |
05-19-2023, 06:06 PM | #3 |
Gary:
Thanks. Vic |
05-20-2023, 07:02 AM | #4 |
McMaster Carr has cotter pin sets in zinc plated and stainless steel in plastic boxes. See https://www.mcmaster.com/products/co...n-assortments/
05-20-2023, 08:18 AM | #5 |
Here are some pics of the box I made. I have not saved the file, but it was from someone on FordBarn, so it might show up in a search.
The box is 10 3/4 X 6 3/4 X 1 3/4 inches. |
05-20-2023, 10:22 AM | #6 |
https://www.harborfreight.com/555-pi..._q=kotter+pins Regards Bill |
05-21-2023, 09:31 AM | #7 |
Are the shapes/finishes of the cotter pins originally used in the Model A the same as the ones commercially available today? Are the profiles of the wires used to form the pins the same, and are the shapes of the loops the same, and are the ends clipped off the same way?
I guess what I'm really asking is: are the modern ones correct for Fine Point Judging? And are any different (perhaps more 'correct') designs currently available? And if not, what's the option? Thanks JB |
05-21-2023, 05:23 PM | #8 |
A good friend gave me this one years ago. I couldn't imagine doing without it.
05-21-2023, 05:39 PM | #9 |
Another view which is identical to the one in the earlier post.
05-22-2023, 05:42 AM | #10 | |
I am getting to this party kinda late, but I made a PDF copy of my spreadsheet that we use to label the inside of the containers when we make in-house kits. I also included a sheet that has hyperlinks to what cotters we use. I know this is a larger quantity than most will ever use, but maybe you can order some and make multiple kits to share with your friends?? . |
05-22-2023, 05:19 PM | #11 |
Here is that article from Doc Kalinka. I think it is attached ?
05-22-2023, 06:21 PM | #12 |
Where did your friend purchase the storage container?
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
05-22-2023, 06:35 PM | #13 |
I'm sorry, it was a gift and he has passed away.
05-22-2023, 07:38 PM | #14 |
I made my cotter pin box a few years ago. I purchased the box at Walmart. This is the item description and number Flambeau Tuff Tainer 4007, 24 Compartment Divider with Zerust Protection. It appears that they still carry this item. Less than $5.00. Supergnat
05-23-2023, 08:40 AM | #15 |
I purchased mine at Lowes several years ago. It is called a '12 compartment parts box'. I don't see them listed any longer on their website (-which is no surprise coming from them ) but I can send you my Excel file and you can modify it to fit whatever size box you choose to use. |
