05-12-2023, 06:19 PM | #1 |
Evapo-Rust
Anyone ever use Evapo-rust to clean rusty parts? It is a process that converts the rust so that it can be removed easily. I use it on rusty bolts and small pieces. Works great.
05-12-2023, 06:28 PM | #2 |
Re: Evapo-Rust
Yes, I use it for the same thing. also anything that is fragile. JP
05-12-2023, 07:01 PM | #3 |
Re: Evapo-Rust
Yep, works great but pricey for what it is and wears out fast (at least for me). I've still got several gallons but have pretty much switched to Rust 911, especially when I need quantity. Gallon is $80 but dilutes to 16gal and seems to last longer.
05-12-2023, 07:39 PM | #4 |
Re: Evapo-Rust
Just a coupe of pictures
05-12-2023, 09:50 PM | #5 |
Re: Evapo-Rust
Works great but you may want to try Rust 911. Works the same but it is in contracted form that you mix with water.
MUCH cheaper. You can buy it on line. |
05-12-2023, 10:49 PM | #6 |
Re: Evapo-Rust
05-13-2023, 03:37 AM | #7 |
Re: Evapo-Rust
Evapo rust works well for me if the part is greaseless
Don’t use that much but do intend to try911 next |
05-13-2023, 07:03 AM | #8 |
Re: Evapo-Rust
911 works well for me too.
Sent from my iPhone using Tapatalk |
05-13-2023, 07:49 AM | #9 |
Re: Evapo-Rust
Evaporust really works at 80-90-100 degrees temperature, DO NOT put it back into a closed container or you will kill it, don’t ask me how I found this out. It will also work as a penetrate to loosen screws and jets in carburetors
05-13-2023, 07:53 AM | #10 |
Re: Evapo-Rust
Thanks, I will remember that the next time.
05-13-2023, 10:13 AM | #11 |
Re: Evapo-Rust
Wonder how this would work to de-rust the inside of a gas tank after it was washed out before sealing.
05-13-2023, 10:33 AM | #12 |
Re: Evapo-Rust
do a search- its been talked about ad nauseam here on the Barn........
05-13-2023, 02:16 PM | #13 |
Re: Evapo-Rust
05-15-2023, 12:26 PM | #14 |
Re: Evapo-Rust
I have used evap rust with pretty good success for several years. The temperature is critical, typical garage temp (especially sitting on the concrete floor) is not warm enough for it to work
05-15-2023, 02:28 PM | #15 |
Re: Evapo-Rust
If you really want to do a nice job on fasteners, use a Harbor Freight vibratory tumbler with small ceramic media while using the Rust911 as a wetting solution in the tumbler. Remove the fasteners and then blot dry. Then use Gun Bluing solution and a sealer on the fasteners and they look really nice.
