05-04-2023, 12:13 PM | #1 |
1958 ford flywheel
I'm having trouble finding a ring gear for my 1958 ranchero 292. I ordered one from pioneer but it did not expand enough to go over the flywheel. Took it to 500 degrees. The ID of the ring is 13.352. Od of flywheel is 13.5. Do I have the wrong flywheel? If so where can I get one
05-04-2023, 05:47 PM | #2 |
Re: 1958 ford flywheel
FORD did not offer a RG for the 1958 292CI FM & CM AT FLYWHEEL. You had to buy the flywheel -
And you will find that unobtainium -
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
05-05-2023, 01:20 AM | #3 |
Here is an ad by DENNIS CARPENTER but this is for a 1958 FM or CM with an FE. The ad does not call out for an FE -
https://www.dennis-carpenter.com/en/...ring-gear-assy SIMILAR THREAD - https://www.fordbarn.com/forum/showthread.php?t=323066
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - Last edited by KULTULZ; 05-05-2023 at 01:29 AM. Reason: THE USUAL |
05-05-2023, 08:00 AM | #4 |
So, trying to learn here, what's the solution for cjc56?
05-05-2023, 08:09 AM | #5 | |
05-05-2023, 08:30 AM | #6 |
05-05-2023, 09:55 AM | #7 |
That's what I was wondering? I don't remember Ford selling a 6384 for AT flex-plates/flywheels but I may be mistaken. # should be EAA-6384-A for most MT flywheels that year.
05-05-2023, 09:58 AM | #8 |
Hello Look at post over on Y-Blocksforever. If is a manual trans and OD of mounting flange flywheel 13.47 inches. Just went thru this. Cos
05-05-2023, 10:24 AM | #9 | |
The link cos is referring to: http://forums.y-blocksforever.com/Topic164209.aspx Terry
05-05-2023, 12:54 PM | #10 |
05-13-2023, 10:11 AM | #11 |
CJC56 Did you get ring gear problem figured out?
