04-26-2023, 10:29 AM | #1 |
Rebuild kit for a 1953 Mercury dual action fuel pump
Anyone have a source for a rebuild kit for a dual action fuel pump for a 1953 Mercury?
I have tried about everyone that I have used in the past and no luck. Thanks in advance. |
04-26-2023, 10:41 AM | #2 |
Re: Rebuild kit for a 1953 Mercury dual action fuel pump
If you have the part no check with some of the military vehicle parts dealers.
04-26-2023, 11:06 AM | #3 |
04-26-2023, 11:08 AM | #4 |
There were two different designs of dual or double action pumps but this was the only link I could find. The others are Willys Jeep & Kaiser parts.
http://www.allfordparts.com/shop/cat...-double-action This Link mentions Charlie Schwendler. He's not on here but he's still around. https://fordbarn.com/forum/showthread.php?t=283377 Last edited by rotorwrench; 04-26-2023 at 11:32 AM. |
04-26-2023, 11:30 AM | #5 | |
Thank you for the lead. |
04-26-2023, 11:32 AM | #6 |
04-26-2023, 11:38 AM | #7 |
You might check with this outfit as well.
https://www.then-now-auto.com/produc...uel-pump-kits/ My old Mercury cars didn't have them from the factory since they were made for the flat land western states where it doesn't rain as much but I ended up with a few of them anyway. My pop likely tried them out or they came off of other engines he had since trucks used them too. They were made by AC and should have an AC number on them. The FPA-186 kit is the late one for flatheads but I can't tell you for sure if it fits yours. Last edited by rotorwrench; 04-26-2023 at 11:52 AM. |
04-26-2023, 11:39 AM | #8 |
https://daytonaparts.com/ Have you tried this one?……Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
04-26-2023, 11:47 AM | #9 | |
Thanks any way. |
04-26-2023, 11:48 AM | #10 |
04-26-2023, 11:49 AM | #11 | |
04-26-2023, 11:55 AM | #12 |
Try Arthur Gould, he is a rebuilder of fuel pumps and advertised in Hemmings. I don’t know if he sells kits but should be able to get a rebuilt pump if you can’t find kit.
04-26-2023, 12:04 PM | #13 |
I think the tall one is the 1539544 and the short one is the 1539776 which is likely a later pump. The one in the photos looks like a 9544. These were AC numbers I believe. The FPA-176 kit should work for the 9544 (Then and Now Automotive)
04-26-2023, 03:16 PM | #14 | |
https://www.then-now-auto.com/produc...fuel-pump-kit/ Mine is not stamped AC, but from the one I found on line, I think the AC number my pump is 5592316 Thanks again for the lead. Last edited by Merc Cruzer; 04-26-2023 at 06:50 PM. |
04-26-2023, 06:00 PM | #15 |
call Cowboy Charlie in Florida, he makes his own kits,I have been buying kits from him for yrs,
04-26-2023, 08:38 PM | #16 | |
04-27-2023, 12:25 AM | #17 |
Just curious, what is the purpose of the dual action pump? I have never seen one on a flathead. My 52 seems to work fine with the single action.
https://www.youtube.com/user/roosty6/videos |
04-27-2023, 12:48 AM | #18 |
The dual action is for providing vaccum to the windshield wipers. Some will just buy a single action pump (which is cheaper) and use another source of vacuum and others convert to electric wipers if they changed their electrical to 12 volt. Me I don't drive my old stuff in the rain, period.
04-27-2023, 02:16 PM | #19 |
It acts as a vacuum booster. It's connected to the manifold for a low pressure source and it is further lowered by the pump to keep the windshield wipers from crapping out under load conditions like they tend to do normally. It keeps the wiper motor speed more consistent under all conditions. The drawback is that it takes a bit more wear and tear for a system that only functions when it's raining or snowing. If you have one of these then of course you will need the windshield washer option on there too.
04-27-2023, 02:41 PM | #20 |
The top chamber pumps gas and the bottom chamber is the vacuum pump.
What does the vacuum, on the bottom of the fuel pump power? 1. Wiper motor 2. Heater water valve 3. Windshield washers And when that is not enough, you add the Trico Electro-Vac (yes, made by the same manufacture as the wiper motor), to keep your wipers going, when you are climbing a hill. The neat thing is, that it will power the wipers, even when the car is turned off. If I am not mistaken, Lincolns had a power antenna, that was vacuum powered. Last edited by Merc Cruzer; 04-27-2023 at 04:33 PM. |
