04-12-2023, 11:44 AM | #1 |
Another Question - C59A block coolant passage
I just noticed this threaded passage in the block just behind the water pump mating surface as I was prepping it for paint. In all the years I’ve now had this engine, I don’t think I ever noticed them. Going through the flathead books I have, I see no mention of them. The one book by Mike Bishop & Vern Tardel show a block being assembled with the port blocked off, while I. The book by Tony Thacker & Mike Hernan the block used in their assembly pics has no port. So, the question is what were these ports for? Will now need to get more 1/4” NPT brass plugs.
04-12-2023, 12:24 PM | #2 | |
Re: Another Question - C59A block coolant passage
04-12-2023, 12:28 PM | #3 |
Simply a drain plug. Not uncommon.
04-12-2023, 04:05 PM | #4 |
Thanks. Just curious. Will plug them up.
04-13-2023, 11:24 AM | #5 |
The Canadian blocks were all cast across the river in Windsor Ontario and they did things a bit different than the Rouge on the other side. Ford did various things for block drains over the years so nothing surprises me much anymore.
04-13-2023, 10:46 PM | #6 |
04-14-2023, 05:51 AM | #7 |
I have vintage brass petcocks in all of mine. They work great for draining every last drop out of there when I change the coolant, like you're supposed to do every two-years.
