04-04-2023, 11:24 AM | #1 |
Thread chaser thread
I just had to clean up some damaged threads on a steering wheel shaft. Some PO had done some beating on the end. We all know that even if I had a 5/8" fine thread die, it could be tricky getting it started correctly with the bad end even after some careful filing. I taught myself this trick many years ago when working on an axle. I take a good nut of the size required, cut a slot clean through one side with a cutoff wheel. Most of the time I need to cut a slot in the opposite side for some give. Now spread this nut open with a chisel until it will start. Once you are sure it's on straight, wiggle the chisel free and bottom out the nut on it's threads. Now with vice grips closing the gap, back the nut outwards. Sometimes it takes two or three passes, closing the gap with the vice grips. Sometimes I get a back cut on the through slot such that it meets the damaged threads at a good angle of attack. A lug nut is a good candidate if the size allows as they are tall. Castelated nuts with their turrets cleaning the threads is also a plus. Maybe this is a common fix, but I have never worked with mechanics, so I do what I can with what I have. Never throw away one of those big diameter nuts from a full floating rear axle.
04-04-2023, 11:30 AM | #2 | |
Re: Thread chaser thread
04-04-2023, 11:52 AM | #3 |
Necessity.........the mother of invention......you must be the elder son.......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
04-04-2023, 02:56 PM | #4 |
I've done that exact same job but got all fancy and split a die in 2 pieces. Those old type tap and die sets that have split dies are great for this. I have a UNC set but not a UNF one. There is a rethreader tool that unhinges and has common thread forms. They're pretty handy if you can find one.
What you did with the nut is great if nothing else comes to hand. |
04-04-2023, 03:50 PM | #5 |
I love your custom tool approach! Gotta make do when you're almost off the grid.
04-04-2023, 03:57 PM | #6 |
04-04-2023, 04:01 PM | #7 |
That is a good tech tip
04-04-2023, 05:58 PM | #8 |
Nice. I have to do this exact job and was kind of worried about it. It seems you only get one try!
What is the size of the thread on a 40 column?
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
04-04-2023, 06:05 PM | #9 |
Here's the real deal. Another one of those expensive tools you seldom use...but nice to have when you need it
04-04-2023, 06:07 PM | #10 |
04-04-2023, 07:33 PM | #11 |
04-05-2023, 07:23 AM | #12 |
Good tip, Gary.
I dig coal, which provides motivation for EVs. |
04-05-2023, 04:08 PM | #13 |
Just a note of caution: The early ford differential has interference fit threads to fit the axle housings, intended to help prevent oil leaks. Do not chase those threads.
Alan |
04-05-2023, 08:15 PM | #14 |
So, yer sayin' we better not goober those threads up or it's a new housing. Thanks for the heads up.
04-06-2023, 04:22 AM | #15 |
The tool that cas3 shows is the type of tools that I have. They work well and are worth the money ( $ 45.00 ) that I paid for each of them.
04-06-2023, 08:43 AM | #16 |
I found that working by yourself or living away from normal civilization(?) is a good way to think up ways of doing things. Most of the stuff I work on is already broke. So I cant make it worse(maybe)
04-06-2023, 08:53 AM | #17 |
It's this sort of knowledge that keeps me coming back to places like this. My old Friend Slim who owned a junk yard down by the county line once told me to stop trying to take the bolts out of a 40 ford front fender to get it off. He took my 1/2"drive set and tightened every bolt maybe a quarter turn and they all snapped off. This guy was in his seventies and it took him about 20 minuets to pull that fender. I was stunned. Know how is king and common sense is his sword. Thank you Gary for the know how. Tim
04-06-2023, 10:40 AM | #18 |
Thanks for the kind words. As you can tell from my wordy posts, we don't get a lot of visitors out here. My buddy likes to say "One thing for sure Gary, your tombstone won't say 'He was a man of few words' "
Oh and I just posted this on the chinese knock off carb thread, but I'm still feeling it and in the spirit of 'Old Guys Rule', I'll post it here as well. Lots of knowledgeble looking old guys in this clip! https://www.youtube.com/watch?v=qBh-m1yTZS0
04-16-2023, 10:00 AM | #19 |
After reading this thread I thought I should have one like posted above. Found one at a swap meet yesterday but the $40.00 asking price seemed a bit steep to me. But a couple of spaces away a guy had one for 5 bucks. Much more in my budget range. I had to tell him what it was for. Hopefully I'll never need it but if I do I've got it. Unless I forget where I put it.
Making the simple complicated for over 30 years. |
04-16-2023, 10:08 AM | #20 |
Well that sure was a bargain ! You can afford to take the wife out for breakfast now and score some points
