03-25-2023, 09:07 PM | #1 |
'61 full size Mercury heater core availability
Hi. I noticed antifreeze leaking from my Mercury Monterey's heater box inside the car today. It could just be the connection between the hot water control valve (also located in the box, according to the shop manual) and the heater core, or it could be the core itself or control valve.
I won't be able to get the unit apart til later, but I thought I'd check the price and availability of heater cores and control valves online. Unfortunately, I'm not finding any heater cores or control valves for the full size Mercury in '61 (352 engine) online. And no cores with the same kind of inlet/outlet configuration. Does anyone know of a source for new heater cores for this car? I also looked for '61 Galaxie cores, thinking they may be the same, but I found none of those either. Are there heater core repair/refurbishment services anywhere? Thanks for any help. |
03-25-2023, 09:55 PM | #2 |
Re: '61 full size Mercury heater core availability
I've bought parts from only one of these places, (vanpelt, 100% happy with them)
just putting the other names out there in case it helps. https://cgfordparts.com/ http://greensalescompany.com/ http://www.vanpeltsales.com/ https://www.tascaparts.com/vintage-ford-parts https://www.vpartsinc.com/automobile...coln-mercury-0 https://classicautoparts.com/ https://www.henryspartsdepot.com/ . Last edited by dmsfrr; 03-26-2023 at 06:50 AM. |
03-26-2023, 12:12 AM | #3 |
Wow, thanks a lot, dmsfrr! I'll check them out and let you know what I find.
Jim |
03-26-2023, 12:47 AM | #4 |
you can probably have the heater core repaired/ re-cored by a good radiator shop, if you have one near by. If the ends(tanks) are good they can reuse them. Check with shoebox central , they may be able to rebuild your old control valve
03-26-2023, 09:25 AM | #5 | |
Add Concours Auto Parts in Carson City NV to the list. https://concoursparts.com
Making the simple complicated for over 30 years. |
03-26-2023, 12:36 PM | #6 |
03-27-2023, 08:41 AM | #7 |
If you need a 1961 Galaxie heater core to have pressure checked and fixed if needed, I have a couple available. Bob
