11-20-2022, 05:27 PM | #1 |
Anti-seize lube for aluminum cylinder head
I have installed an aluminum "Rocket" head from Secrets of Speed on my Model A. I wonder about using this: https://www.amazon.com/Jet-Lube-Anti.../dp/B009VO2O1Y
What does everyone think about using anti-seize on spark plug threads? Thank you in advance. |
11-20-2022, 05:30 PM | #2 |
Re: Anti-seize lube for aluminum cylinder head
I always use some anti seize on sparkplug threads going into aluminum heads, just don't overdo it. The plugs still need to ground to the head.
11-20-2022, 06:00 PM | #3 |
Guten Abend Paul.
Never use copper paste with aluminnium. Use white ceramic grease. (It is also available for aircraft engines as heat-conducting paste.)
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
11-20-2022, 08:55 PM | #4 |
Get regular spark plug anti seize at your local parts store. All new car have aluminum heads and use it. Check the torque specs don't overdo it.
11-20-2022, 10:15 PM | #5 |
Gents -
After considering the advice, especially the part about not using anything with copper in it between steel and aluminum threads, this is what I ordered: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Thanks to all. Bj |
11-20-2022, 10:28 PM | #6 |
11-21-2022, 10:57 AM | #7 |
I once tried using aluminum anti-sieze on spark plugs in a cast iron head, never again. After 3 or 5000 miles, removing the plugs was a chore, the anti-sieze had turned into a tough paste, almost like the plugs were glued in.
11-21-2022, 11:48 AM | #8 |
I used copper base antiseize but changed over to nickel based for stainless fasteners on the turbine engines. Either is fine for model A engine fasteners. Any antiseize should work on them since there are no original stainless fasteners in the early Ford cars.
