11-07-2022, 11:36 AM | #1 |
Zenith Carb with brass screw-in GAV seat
Is a gasket placed under the brass seat for the GAV in the Zenith Carb? Thank you, Ed
11-07-2022, 12:28 PM | #2 |
Re: Zenith Carb with brass screw-in GAV seat
yes, ( well there should be! but I must admit I doubt if it is absolutely vital )
11-07-2022, 04:23 PM | #3 |
The brass GAV seat for the Zenith is pipe thread, so it should NOT need a gasket.
11-08-2022, 04:16 AM | #4 |
Uh? "The brass GAV seat for the Zenith is pipe thread,..." I think not! I don't know where you got that information from but according to all the carb books and articles that I've consulted the thread of the brass GAV seat is M5x .75 metric ( same as the the jets ) . The only pipe thread that I am aware of on the Zenith is the brass GAV housing 3/8-24 SAE ( I must admit I have never measured any of them to establish veracity!)
11-08-2022, 09:54 AM | #5 |
11-08-2022, 10:33 AM | #6 |
11-08-2022, 11:37 AM | #7 |
yes dig out old ones!!
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:37 PM. |
11-08-2022, 11:41 AM | #8 |
NOTICE:
Some castings are softer than others ... Do not hammer a screwdriver into the gasket in an attempt to remove the old gasket. Doing so will put a groove in the cast iron seat where brass GAV seats to the casting ... then all you have is a junk lower casting! Last edited by Benson; 11-17-2022 at 11:22 AM. |
