10-15-2022, 06:10 PM | #1 |
Over heating. Can't figure this one out.
Howdy boys, a young fellow in our club has a '29 that has a problem of overheating that I can't help him with. Long story short, it's had two engines in it, and it continues to overheat. Timing is correct, water pump seems normal, radiator has been back flushed, along with the block, and it still overheats. He is going to clean the radiator with a coolant system cleaner and see if that helps, but I am doubtful, due to the cleanliness of the water when we flushed it today. The only thing I can think of is there must be a reason water is not flowing. Damned if I know. We've had the pump off and it seems to be in good condition. The radiator seems to flow normal, but I haven't measured gpm flow. Should be around 40 if I remember correctly. I guess we're going to have to pull the radiator and clean it out professionally, unless we can get it to flow better. Any suggestions, other than the obvious, would be appreciated. Thanks guys, always like to hear your thoughts.
10-15-2022, 09:37 PM | #2 |
Re: Over heating. Can't figure this one out.
I have a similar problem. I'll be eagerly reviewing the answers
10-16-2022, 07:38 AM | #3 |
Timing is to RETARDED or get a new Radiator That was my 3 month long demon RAY
10-16-2022, 08:07 AM | #4 |
You said the car had two engines in it. Did this problem occur with the previous engine?
10-16-2022, 08:21 AM | #5 |
More information please ! What are the signs of overheating, what temperature and how it’s taken, at what parameters are you overheating, idling, slow speeds, highway speeds, etc
10-16-2022, 10:39 AM | #6 |
10-16-2022, 10:50 AM | #7 |
Stand by boys, I'll get back to you in a couple hours. Thanks!
10-16-2022, 11:06 AM | #8 |
If both engines ran warm, then it's either your timing or radiator or a combination of the two. With the weather right now, hot plugs shouldn't do it.
Test your radiator, it should flow 38 gallon in a minute. You'll find videos on Youtube explaining how to test it. Also, as Ray64 said. More than likely your timing is to far retarded. Regards Bill |
10-16-2022, 11:47 AM | #9 |
If the radiator is scaled up inside, (from using hard water) it may flow good but won't cool properly. The scale restricts the heat transfer from the coolant to the radiator tubes. Some people use vinegar to descale the radiator.
10-16-2022, 01:35 PM | #10 |
As Big Hammer said, what are the signs of overheating? Steam? Coolant discharge?
What is the age of the radiator. They do get old and loose the ability to cool. Rodding as Terry H suggested may help. There are many possible reason for overheating. You will have to play detective to eliminate each possible cause one at a time. You have already done some of that by looking at the timing and fuel ratio.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 10-16-2022 at 01:44 PM. |
10-16-2022, 02:07 PM | #11 |
When I bought my car, it had been timed with the spark travel all the way down. Wonder the thing even ran...
10-16-2022, 07:09 PM | #12 |
Another issue is if the fins get loose and the tubes can't transfer the heat to them efficiently.
10-16-2022, 08:15 PM | #13 |
Agree with Ryan check fin connection
10-16-2022, 08:51 PM | #14 |
Good Evening...A plugged muffler and or tailpipe might be part of the problem...also the head gasket could be loose...or warn out. It is also a good idea to take off the lower water pump inlet and the water pump and then insert a power washer nozzel into the botom water entry and fire away, then into the one in the head and do the same thing. I turned a driveway orange...Her magesty was not pleased. She did not smile at me. Ernie in Arizona
10-17-2022, 12:08 AM | #15 |
Buy a cheap ir temperature gun and shoot the radiator. That will tell you how well the tubes are transferring heat.
10-17-2022, 01:26 AM | #16 |
To see if the radiator is cooling efficiently, get an infared temp gun, and do few checks in various spots on the core. It will show up blocked areas by being a lot cooler at the same height, and should show a temp drop from top to bottom.
10-17-2022, 06:41 AM | #17 |
[QUOTE=Seabees;2174227]Howdy boys, a young fellow in our club has a '29 that has a problem of overheating that I can't help him with. Long story short, it's had two engines in it, and it continues to overheat. QUOTE]
You say "continues to overheat" - guess that means both engines overheated. If both engines the thermostat may be defective if it has one. Was the top hose replaced? Last edited by aermotor; 10-17-2022 at 07:15 AM. |
10-17-2022, 10:19 AM | #18 |
Howdy boys, sorry I didn't get back to you yesterday. OK, here's the full story. The original engine is worn out, so it got pulled and a replacement was put in. The replacement was .125 over on the bore, but we decided to use it. It ran fine for about two months, then began to overheat. I check the radiator and block with a heat gun and the block was anywhere from 200-230. Way too hot. The radiator was around 170-180. My first thought was timing, so I checked it, right on. Then I thought, not enough flow, so we flowed water through the radiator and block. A little rusty, but not bad, and the radiator seemed to flow adequately. Continued to overheat, so we pulled the pump and it seems normal. Since the engine was bored to .125, I thought that might be an issue. Talked to my builder and he was of the same opinion. They do tend to get hot sometimes. So, the young man who owns the car decided to buy another engine and use it. This engine was taken out of a running car. We watched it run on a stand. Put the engine in and same thing, still overheating in the same spots. The timing is correct, there is no thermostat, and it runs fine, so I don't suspect the head gasket is bad. We pulled the hoses and backflushed the radiator and block. Got some crap out, but not a bunch. Put it back together and same thing, still getting hot. So, I sent him home with it and he bought a cleaning kit for the cooling system, which produced more rusty water, but didn't really help the heating problem. He is going to pull the radiator today and I will take it to the shop and get it taken apart so it can be rodded. It has to be the radiator in my opinion. My reasoning is, the first engine we put in the car had sat for several years with no head on it. Who knows what may have been in the block. Mouse nest? I cleaned out a gas tank that had a rat nest in it once. So, the radiator, even though flowing what looked "ok", may be filled with junk. Yeah, I know, I should have checked this before having him do all the other guess work I had him do! Anyway, that's the plan for now, get that radiator cleaned out for sure. Thanks guys, I'll keep you posted. And yes, I feel like a dumb ass for not paying a little more attention to detail here!
10-17-2022, 10:27 AM | #19 |
I pulled my radiator and filled it with cleaning vinegar - got alot of rusty gunk out - soaked it for several hours
10-17-2022, 12:58 PM | #20 |
Does not seem to hot to me, but I am in Texas and you are in Oregon.
